Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Refrigerator not cooling
Light is on and sounds like freezer fan is running but no cooling
  • 126 Answers
IS THE FREEZER SIDE COOLING.
Posted on Sep 17, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: The fan is running, but the refrigerator and freezer are not cooling. We cleaned the coils... any other suggestions?
Check the compressor and the relay. Make sure they are working when you turn on freezer and fridge to the max. If the compressor does not start then you need a new relay. If the compressor starts then it is your thermostat that has gone bad and must be replaced. you can find the parts on repairclinic.com and order them with instructions on how to remove the bad part and install the new part
Posted on May 20, 2009
Maytag317
  • 1136 Answers
SOURCE: Does not cool. Compressor is running, fans are
Hi, Look in the freezer section and see if there is frost building up on the rear inside panel. If the is frost, on of three parts are bad in the automatic defrost.
If there is no frost, the compressor might be weak and not pumping the coolant as strong as it should.
Remove the rear inside panel in the freezer sevtion and see if the evaporator is frosting at all.
Please let me know what you find so I can assist you further with this issue.
Vic
Posted on Jun 27, 2009
  • 27 Answers
SOURCE: Kitchaid Superba KSRG25 not cooling freezer or
either stuck in defrost or compressor failure or loss of gas
Posted on Jul 29, 2009
rafaelrs38
  • 12 Answers
SOURCE: freezer and refrigerator stop cooling, back of
clean all the dust and form the gril on the back of your frig
Posted on Aug 10, 2009
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
My fridigaire FFUS2613LS is not cooling
Good Afternoon Timothy,
I understand your Frigidaire refrigerator, model# FFUS2613LS, is not cooling. I also see that you hear the motor running, can't feel the fan running, and it is not cooling. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the fan is not running and your refrigerator is not cooling. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire FFUS2613L Side by Side...
I have a VERY loud fan sound coming from the refrigerator when it is cooling.
Check out that the fan is not hitting ice build up in the freezer...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 09, 2010 | Whirlpool Refrigerators
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Refrigerator and freezer not cooling
if the light is working then it has power so it may have just went into defrost and it takes about 30 minutes to come back out / if it does not come by on within a hour then i also think you may have a bad temp control / larry
Nov 30, 2008 | Frigidaire FRT18S6AW Top Freezer...
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
