Question about Nintendo Wii Console
Problem with wii
The red light by the power button will only come on when the power cable is pulled out then put back. Then when the power button is pressed the light goes green then goes out. Is this a problem with the power pack?
I did setting up and come up w/ Language--ENGLISH
and I hit confirm, nothing happen, it means the remote cannot talk w/ the Console, then I did the standard mode synchronization, still the same.
How to make the communition betwenn the console and the remote?? Charlie
Posted on Jul 06, 2008
Wii has solid red light, won't turn on, faint ticking noise
if it was dropped check the bluetooth module , they can come unplugged and the wii will not function. Children love to put change in the wii which can short it out. Never bridge a fuse as it can cause unsafe conditions and potentially a fire hazard .
May 08, 2014 | Nintendo Wii Video Game Consoles & Games
Tip
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
I hope this tip helps!
on Apr 09, 2010 | Video Game Consoles & Games
Tip
How to connect you Wii to your TV, Out of the Box.
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
on Feb 15, 2010 | Video Game Consoles & Games
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
Wii does not come on. All cables plugged in, but no lights. What is wrong?
If you plug in your Wii and the power light ISN'T RED BEFORE YOU TURN IT ON
1 Disconnect everything
2 hold the power button down for 20-30sec
3 Plug everything back in
4 The power button should be red
5 Press it
6 It should be on
7 If not you have power supply problems and need to get a new one
Thank you for your time, Good luck and I hope this works
Jun 08, 2011 | Nintendo Wii Console
I accidentally set my wii to HDTV settings and I need to reset it back to normal tv but my screen is so messed up I cant see options or anything
May 01, 2011 | Nintendo Wii Console
MY POWER WENT OUT, NOW THE CONSOLE WON'T COME ON AGAIN. THERE IS A RED BUTTON YOU PUSH AT SAME TIME AS ANOTHER, FORGET WHAT OTHER BUTTON! CAN SOMEONE HELP?
press and hold power button for 10 seconds and plug out power cable put it back in and press on power and wii should work
Dec 15, 2010 | Nintendo Wii Console
Plug in the WII. Red power light comes on. When you hit the power or eject button, the blue light on power switch and around the disc opening flash (once), and the all power is lost. Pull the plug and...
NINTENDO WII Red Light error, or Red ring of Death RORD is avery common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screenstarting with "E".
Red light problem can be fixed! there is a nintendo wii repairguide available that covers this problem and also all other common nintendo problems. You can get your copy nintendo wii Repair Guide, you can download it andget help to fix your console. Please feel free to message me if you needfurther assistance........
all the best.........
Dec 07, 2010 | Nintendo Wii Console
How to connect a tv to a wii
Feb 15, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
Wii wont turn on
HI,
Mine did the same thing. Open up the small door where you put a memory card and push the red reset button. That may help to clear it. If it doesn't work then the best thing is to have it looked at.
Oct 26, 2009 | Video Game Consoles & Games
Nintendo Wii Console Logo
75 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
