Question about Whirlpool Refrigerators
Ice maker water line appears to be frozen on gd5sha. ice maker won't function.
  • 958 Answers
Thaw the whole refrigerator for a whole day to thaw the ice inside the water line. it will reset also the timing of the ice maker.
Posted on Jul 05, 2008
The ice maker in my Whirlpool Gold (Model GI6FDRXXY07) stopped making ice. I can get water from the door and can hear the ice maker cycling. It is calling for water but the flow valve is not opening.
The same valve that the water comes from except there are two halves to the valve. The valve you need is a=> Whirlpool Refrigerator Water Inlet Valve WPW10312696 The problem is with these models the ice maker tends to function a little causing you to believe it is OK when they are worn out. I can point you to a manual to see if the water valve works by going to page 18 HERE and use a jumper wire between test point L and the letter V. Make sure the wire is insulated so you don't get shocked. Otherwise the ice maker may need to be changed and it is less expensive than the water control valve Ice Maker=> HERE
APPLIANCE911
E-Mail Contact Me Here
Aug 29, 2016 | Whirlpool Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
No ice being made. The water is not eing supplied to the ice tray. The water dispenser in the door is working fine.
Well since water is making it to your door the line itself is functioning. You might want to check and see if the fill tube to the ice maker is frozen. Also try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it does then the ice maker is at fault.
Mar 19, 2011 | Refrigerators
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker works but water dispenser stopped working
There sould be a set of water control valves on rear of refrigerator and where the water comes into refrigerator dispenser and ice maker. When one goes bad you replace both. You can test the windings in each coil or test for voltage while someone presses dispense water.I will ty to locate one set with your model number. Sea Breeze
Mar 20, 2010 | Refrigerators
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
No ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will make the switch to start the cycle.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 19, 2009 | Refrigerators
Icemaker is not making ice
check the fill tube on the ice maker to see if its frozen upo. if it is you are going to need a new solinoid valve due to it leaking thru the valve and freezing up.
Apr 05, 2009 | Whirlpool GD5SHAX Side by Side...
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Water line to ice maker frozen
Check to make sure that the damper between the freezer and fridge is not broken or frozen open. Make sure that you shut off the water supply to the fridge until you get this fixed because the line could crack and then you could flood the house.
Jan 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
210 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
