SOURCE: i forgot my passcode and now my iphone is disabled.....
how do i find out what my passcode is
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
SOURCE: I forgot the 4 digit passcode for my iphone. Can
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
SOURCE: I had a iphone 3gs
If your iPhone 4 is brand new, you might wanna restore it to remove that passcode. This is what you need to do:This is how you can recover your device:
After the restore is complete, please do not choose restore from backup, rather, choose set up as new device.
You can just sync all info after that.
If you don't get it at first, try holding the buttons for lesser time or see the other procedures and some screenshots on my tip (link below):
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE or contact me personally at this email:
[email protected] or add me on Skype: ebayseller.ca
