Question about Aiwa Audio Players & Recorders
Power on/off problem
I have an Aiwa NSX - VC 38 Digital audio system. I cannot on the system. when plug to the supply, power LED shows low light. But when I press the power on off switch, a click sound ( relay ) appears . No lights in any of the display side. I try to switch on many times, it may switched on and work very well. What is the problem?
Boba
  • 64 Answers
SOURCE: No Power
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Posted on Mar 01, 2006
techman
  • 3130 Answers
SOURCE: power turns off immedietly
Yeppers, when you where changing out those speakers, you shorted them and that in turn blew out the audio output IC inside this unit. This will require you to disassemble the unit, locate the blow output IC abd unsolder it, get a new audio output IC, put some heatsink compound on the back of the new IC, resolder the chip and reasassemble the unit. But before you turn on the unit, double check those speaker wires again to make sure they are not shorted as if they are, even one tiny strand, this unit will blow the IC again. Never work the speaker on any solid state electronic amp when they are plugged in and on. Good Luck
Posted on Mar 27, 2007
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
  • 135 Answers
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
http://www.donberg.ie/warehs/groupba.htm
try here
Posted on Jan 18, 2009
  • 6 Answers
SOURCE: aiwa nsx-9000 is eating my tapes
Well 1st unplug it then you can start by qtip cleaning, blowing internal maintenance service. But for the most part regardless of use or age whenever there is gears, bands moving parts which in time get worn, Now this is were keeping clean extends life, So time to shop for a new 1 because repairs and part availablity exceeds the value,of your problem
Posted on Mar 04, 2009
Stand by problem
do have the the circuit book of aiwa nsx k880
Apr 08, 2014 | Aiwa Audio Players & Recorders
My Aiwa NSX 990 wont come on. Only timer icon come in display and volumew LED keeps coming on and going off at regular intervals
Unplug the power cable completely to turn off and then turn back on again. Check whether there are no lose parts with missing contact.
Most probably it looks like a deeply digital problem with no do it yourself solutions - bring it to the repairman, but I even doubt he would fix it.
You can also download the Aiwa NSX-990 service manual and analyze more specifically your case. Download it from here: http://www.mediafire.com/?jc0ynzoiama or from here: http://www.4shared.com/document/rQ67hcpG/Aiwa_XG-990-NSX-990-NSX-992.html (click "Download Now", not any other button).
Dec 06, 2010 | Aiwa AV-S17 Receiver
NSX-AJ310 power problems
That's nothing strange!! Mine does the very same thing. It's normal, the system's way of powering up, unless when you turn on the power, clicking noise intensifies....., if that's the case, give me a reply.
JaHa
Jul 03, 2010 | Aiwa NSX-AJ310 Shelf System
NO POWER IN MY MINI HIFI AIWA NSX SZ2HR
hello glass fuse may blown inside take the cover off you should see glass fuse in the power supply
shaun
Oct 22, 2009 | Aiwa AWP-ZX7 CD Shelf System
The standy light comes on put no power whats the problem please
Sounds like the power supply is shot. You can buy a new power supply, but that would require pro level re-wiring inside the stereo. I'd get a new one, aiwa doesn't make good stereo's anyways. Go with pioneer
Oct 11, 2009 | Aiwa NSX-DS55 CD Shelf System
AIWA NSX-2700 Alarm
On the remote hold shift and press timer button.
It should go off.
Hope this works for you
Kurt
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
Problems in output
hi, you have faulty power supply ,propably you got missing 5+ volt supply or 12+ v missing to power it up for the cervice in Delhi contact Delhi Service Centre +91 - 11 - 26252669 please don't forget to rate regards
May 07, 2007 | Aiwa NSX-A303 CD Shelf System
51 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
