Question about Nokia 7610
Problem Hi My name is Siya, I've got a problem with my device, when I try to switch it on, it lives a message that says: connection failure please contact your retailer. Do you have any idea about this? Regards Siya Cellphone number: +2779 649 3126
    Master:
  • 726 Answers
It is failing to connect to the net work ring your carrier and see if your sim card is still activated
Posted on Jul 05, 2008
Internet crashes my htc Smart... Help?
The first time you use your device, the Connection Setup displays a notification message to inform you that it will automatically configure your device's data connections, such as 3G/GPRS/EDGE, WAP, and MMS.
  1. On the notification message, select Yes.
  2. If your SIM card supports multiple network operator profiles, the next message displays all network profile choices. Select the profile you want to use, then select OK. The Connection Setup configures your device's data connection settings.
  3. After the Connection Setup completes configuration, tap Restart. Tip: To choose the network operator manually, select Start > Settings > Connections tab > Connection Setup The GPRS/3G settings are preconfigured on your device when you applied for this service with your wireless network provider. If you need to add another GPRS/3G connection:
  4. Tap Start > Settings > Connections tab> Connections
  5. Under My ISP, tap Add a new modem connection
  6. On the Make New Connection screen, enter a name for the connection, select Cellular Line (GPRS, 3G) on the Select a modem list, then tap Next
  7. Enter the Access point name, then tap Next. You may obtain the access point name from your wireless service provider.
  8. When prompted, enter the user name and password. (Check with your wireless service provider if a user name and password are required to connect.)
  9. Tap Finish
Feb 09, 2012 | HTC Cell Phones
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
Hi,I recently bought Samsung B2100 and not able to activate the bluetooth,it displays a NO BLUE TOOTH DEVICE FOUND,TRY AGAIN message,please let me know if the problem can be fixed.
It means you mobile did not find any blue tooth device ,
So please, switch on your another device to whome you want to connect.
I am giving you an example to set the blutooth.
It s a simply way, to solve the problem.you will follow the instruction.
Follow the bellow step.
1. just enter your Bluetooth in your pc.
2. when the icon show your task menu bar just
3. double click on icon
4. add>check on my device >next(ensure phone Turn BT on )
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html
you can see the phone model which Bluetooth on.
just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same
number > in your mobile >finish
For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect
using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user
name and password just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or
you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone
mobile>next
Remember always set the mobile for connection select the yes.
Hope it will help you.
Jan 17, 2011 | Samsung B2100 Cell Phone
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
I have a Samsung GT S5233A handset with vodafone live enabled, I am able to browse internet in my handset, but I want to browse it through my pc windows xp, give me the settings for both my phone and pc
TRY ONE OF THE BELOW SETTING
1)To set up GPRS: a) Go to menu > Funbox > WAP Browser b) Select settings, and choose your profile Once you´ve selected the profile, complete the following fields: Profile name: Vodafone live! Homepage url:http://live.vodafone.in Security: Non-secure Bearer: GPRS IP address: 10.10.1.100 U sername: ______ Password: ______ APN: portalnmms Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WAP Browser > Home To set up MMS a) Go to menu > Messages b) Then go to Multimedia Messages > MMS Profile > choose your profile Profile name: Vodafone live! Homepage url:http://live.vodafone.in Security: Non-secure Bearer: GPRS IP address: 10.10.1.100 Username: ______ Password: ______ APN: portalnmms
2) a) Go to menu > Browser > Proxy settings b) Choose your profile Once you´ve selected the profile, complete the following fields: Profile name: Homepage URL: Bearer: GPRS Proxy use: Enabled GPRS setting: IP address: IP Port:9401 APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Browser b) Then go to current proxy, and select the desired proxy setting Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WWW services > Home
3) a) Go to menu > Settings b) Then go to Connection settings, and click on New Also, complete the following fields: Profile name: Homepage URL: Proxy: GPRS setting: IP address: Port:9401 Bearer: Advance setting: APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Browser b) Go to WAP profile, and select the desired proxy setting c) Then go to Options and click on Activate Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> > Browser > Home To set the proxy settings for MMS, go to: a) Menu > Messaging > Settings b) Go to Multimedia Messages, and select your profile c) Go to desired proxy settings, click on Options and select Activate Top X620, X650 To set up GPRS a) Go to menu > Funbox > WWW services b) Select Proxy Settings, and choose your profile Once you´ve selected the profile, complete the following fields Profile name: Homepage URL: Bearer: GPRS Proxy use: Enabled GPRS setting: IP address: IP Port:9401 Advance setting: APN: Login ID: Password: To set the proxy settings for GPRS, go to: a) Menu > Funbox > WWW services b) Then go to current proxy, and select the desired proxy setting Now that the settings have been completed, you can access the homepage by: a) Going to the idle screen and pressing the "OK / i" key, or b) Go to menu> FunBox > WWW services > Home To set up MMS a) Go to menu > Messages b) The go to Multimedia Messages > MMS Profile > Profile settings > choose your profile
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
Vodafone Live GPRS active, but not able to connect the web
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Apr 13, 2009 | HTC Touch Viva Cell Phone
Internet
u have noy mentioned the connection name. whether it is BSNL, AIRTEL,IDEA,HUTCH . if your balance amount falls under Rs 250 the message comes for BSNL
Jul 15, 2008 | Sony Ericsson K550i Cellular Phone
Problem
RESTART UR PHONE THAN QUICK HOLD THIS THREE NUMBERS GREEN KEY FOR CALL, 3, *.
IT WILL FORMATE UR MOBILE AND RESET UR CODE TO 12345 AND ALSO RESET ALL SETTINGS
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Jul 05, 2008 | Nokia 6270 Cellular Phone
Nokia 7610 Logo
Top Nokia Cell Phones Experts
IT Solution
IT Solution
