Question about GE Profile JS998 Kitchen Range
GE JS998SOH1SS No Display on panel. Touch panel doesn't work. No oven light.
2nd post here. No voltage at main control board (logic board). Went upstream and checked for 12v dc at MPB J1. Zero volts, should be 12 volts. There is current on the MPB because the heatsinks are ungrounded and they're "hot" at 100v ac. No 5 volts dc from the MPB to the logic board either. So basically I believe it's the power board and not any of the 4 boards that are on the panel for the display. If any of this logic doesn't make sense, please enlighten me before the parts dept "enlightens" my wallet of around 250 bucks.
  • 1 more comment
  • vochakov Sep 12, 2008
    Same model JS998SOH1SS . Suddently display stop working, but top does. Why GE Appliences always stop working? Probably they outsource too much. Any thoughts, help.
  • jaydennis Oct 11, 2008
    I went with what was logical and finite - voltage readings were off. All the voltages stemmed from the main power supply board, so it had to be the problem. I ordered a new one online (around $150). Lots of connectors to it, but removed existing board and installed the new one. Presto! That fixed the problem!! Put everything back together and been fine now for several months. If you need some help, write back and I'll walk you through it.
    Jay
  • jirij May 04, 2009
    I have identical problem with GE JS998SOH1SS kitchen range. The oven and oven light stoped working; the control panel (touch and display) is dead; the top heaters are ok.
    Could you please identify the board which you replaced (part number, cost) ?
    You obviously have service manual with wiring diagram, voltages, etc. Where did you get it?
    Did you figure out which part of the board was deffective (power supply) ?
    Is there any additional information/experience you could share ?
    Thnks for your help and information
    -jirij
It is the power board - part number WB27T10551 located under the glass cook top on the right hand side. The part that fails is transistor TOP247Y located on the big aluminum heat sink. Mine was cracked in half. Lots of screws to take out - take your time it's tough to work on as you cannot lift the top off without disconnecting a million wires - just prop it up with a board and you'll be fine.
Brian
Posted on Sep 12, 2009
I have exactly the same problem with the same model (J S998 SOH1SS). Top is working and display went blank overnight. It will be costly and a few times I must stay home.
GE has sales and repair in US - but work is done offshore.
Never will buy from GE again – let them find buyers oversee.
Posted on Oct 10, 2008
Oven display is blank and oven light does not come on
90% of the time this will be the main control board if neither of the displays work. Here is that board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | Ovens
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
Microwave was in use and then shorted out. The breaker did not flip but microwave display went blank and interior light went out. Tested outlet for microwave and it still has power but now microwave is...
There are at least one or too fuses gone, the main fuse located on the main board or behind the control panel, and the thermal fuse located at top on the inner chassis that protects the magnetron, any more than that you are getting into serious money. Remember lethal voltages present when plugged in.
Jun 25, 2012 | GE Microwave Ovens
Beeping with f7 display
HI this is a touch pad or key pad issue. In most models, the touch or key pad are integrated. In this case, you will need to replace the entire control board or EOC(clock).
Now, if the touch or key pad is separate from the main control board, and linked, via linking ribbon, i would advise to use the procedure below to isolate the problem area.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Oct 03, 2009 | GE Ovens
My micorwave
Hi and welcome to FixYa,
Your described problem indicates that the logic circuitry in the main controller board is faulty. Since the logic circuitry is integral to the board, it would require an assembly replacement. On most brands/models, the main controller board is directly behind the display panel. In some instances, it could be a stuck key/button hence the logic would not reset.
Good luck and thank you for using FixYa.
Feb 13, 2009 | Samsung Microwave Ovens
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE Profile JS998 Kitchen Range Logo
599 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
