Question about Fedders AEQ07FBG Air Conditioner
I have an older unit need to know what the top knob does
It has three knobs, fedders 6000btu ac, no front. the middle controls the coolness and turns off, I need to know what the other 2 knobs do and where i can buy a front cover thx:)
  • ddsa31 Jul 05, 2008
    thank you !
  • lindamanhatt Aug 07, 2008
    Hi. I have an older model Fedders Window Air Conditioner-Model #A3T12F2A. It has two knobs on the front with no information plate behind them. Can you tell me What the top knob does and the bottom one. Do I turn them in a clock wise way? to turn it on and off and higher or lowe3rs fan speeds? Anything you can tell me will help. I just turn them blindly now and can't find any info on this unit or even a picture
    Thanks,
    Linda
  • 828 Answers
One of the knobs controls fan speeds, cooling speeds and an off position. Center knob controls temperature and bottom knob more than likely controls air exchange. As for the front cover it would depend on the units age as to if it would be available.
Posted on Jul 05, 2008
2011 Crown Victoria Police Interceptor overheating problem: I observed that the temperature gauge indicator reached the highest point and the warning light lights up while driving with the AC switch is...
nothing to do with the ac charge
the fan not running is a problem so check out the relays , fuses and temperature sensors that control that fan
Nov 03, 2017 | AC Cars & Trucks
Need to know where defrost button is
  • The Regal switched it's temperature control module look around that time So it couple be one of two options.
  • First is the older "slide" type module. For this you move the top of the two left to right functioning settings all the way to the right to engage the defrost and the bottom one all the way to the right to engage the heat.
  • The newer ones have knobs that turn in which case the knob on the far right turns it all the way to the right to engage the defrost and the knob in the middle to the far right to get the most heat.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 11, 2011 | 1992 Buick Regal
Heater fan control arm broken. Stuck in no.4 position. Need to know how to get access to enable me to remove/repair unit.
My 06 Dodge Stratus did this same thing after I had my transmission replaced. I thought the guys at the shop did it but come to find out the actuator that controls the knobs and the turning of the fans for heat and cool air had popped off of the turning mechanism. My uncle took out the glove box so he could access the back of the heater/ac panel. There should be a round mechanism that will spin back and forth when turning the knobs from cool to hot and 1-4 for wind speed control. On top of that know are small notches that hold a white, possibly grey "hook" style device that holds the turning mechanism in place once you change the settings from hot to cold or between 1-4 of the wind speed control. The "hook" style device may be stuck. Try prying the device off of the turning mechanism and getting it in to another one of the grooves on the mechanism. If you can get it to move you should be able to get it unjammed.
Hope this helps. If not, I have no idea.
May 20, 2011 | Mazda 626 Cars & Trucks
Control Knobs
mcdevito75 here, Check at the Fedders website or visit any A/C repair shop in your area.
Jun 23, 2010 | Heating & Cooling
Burners do not adjust and are on full blast and uneven.
The Controls, once they ware out they are not serviceable most of the time.
May 20, 2010 | Jenn-Air JLG7130A
We turned the ac unit control knob in between the high cool and low cool, which turned off the ac unit, but messed it up where it shorts the circuit breaker when we try to turn it back on. What did we do?
YOU MIGHT OF JUST SHORT CYCLED IT . ALL AC UNITS NEED ABOUT 3-5 MIN TO EQUALIZE PRESURE ON COMPRESSOR BEFORE RE STARTING  . IF THIS IS RV AC MAKE SURE YOU HAVE WELDING TYPE EXTENSION CORD
Apr 22, 2010 | Dometic Rooftop RV Air Conditioner
2005 RX8 heater is blowing cold air. Fluids are topped up.
You need to repair the heater core with a soldering gun.
If you do not have heat, or only have heat, IMHO it is most likey the AC/heater control unit. This is the part which has the AC/heat control buttons and knobs.
Easy Diagnosis:
The easiest way to verify this is to turn on the radio, press and hold the power on/off button and press and hold the scan-up button for a second (full second). The word "A/C TEMP" should appear on the left of the display and a number from 0 to 16 on the right. I suspect yours will have the number 0 (or 16 if heating only problem) displayed no matter where you turn the temperature control knob. If this is the case you could turn the temp. knob to full heat and see if it goes to 16 after pushing down or to the right on the knob.
In a working system, the number moves evenly in increments of 1, from 0 to 16 as you turn the temperature knob.
Easy Fix:
I was able to take mine out and solder 3 loose connections to fix it.
The beginning steps are the same as for any radio removal procedure and check for loose connections.
Dec 14, 2009 | 2005 Mazda RX-8
Dash Control Unit Replacement
You can save a LOT of money by fixing it yourself.
All that is wrong with the knob are broken wires from the knob's PC board to the main PC board on the AC control.
All you have to do is remove the AC main control, take it apart, and resolder the broken wires from the PC board with the knob on it, to the main AC pc board. There are 3 wires, any number could be broken.
If you take it apart and solder the broken wires, this WILL fix your issue. Just make sure you put the wires back exactly where they go.
A FIXYA rating (4 blue diamonds) would be most appreciated for my assistance.
Mar 21, 2009 | 2002 Toyota Highlander
Looking for: ProCom Model MNO60HBA (about 3 years old) 6000BTU-Natural Gas-Serial#3620775. I want 3 of the plastic like adjuster knobs on top of the heater. Not the igniter button but the one to allow gas...
Control knobs can be purchased from Procom customer service at 877-886-5989. If you can't find them there, call Kozy World's customer service department at 800-776-9425 and tell them you need a control knob for a KWN109 (same size heater, manufactured by Procom, so same control knob).
Mar 07, 2009 | Procom ML060HPA Heater
Fedders AEQ07FBG Air Conditioner Logo
180 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
