Question about True T-49 Side by Side Refrigerator Commercial
Kitchenaid refrigerator not working
Hi. Our Kitchenaid side by side refrigerator, KSRG25, stopped working sometime overnight. We awoke to melting ice in the freezer compartment and everything warming. We can hear a fan running - we're wondering if it's stuck in defrost mode?
  • 958 Answers
It would not be likely to stuck in defrost mode but my guess would be the compressor is not running. overheated or the condenser is full of dirt. as you said , you can hear fan running, is it inside the ref or outside?..or both?..if that is the case, then it is on freezing mode because the fans would not run on defrost mode..i hope i was able to help..
Posted on Jul 05, 2008
Ice maker makes ice but will not dispense it. water dispenser not working either.
check and make sure ur ice is not melted together. blockage can cause an issue
Jul 08, 2012 | KitchenAid Superba Architect KSCS25INSS...
Ice maker all of a sudden stopped working.
Remove the ice bucket and look for ice hung in the fingers. Use a hair dryer to melt a jammed ice cube. Keep at it till the fingers move free and advance to the next harvest cycle. If the ice mold is empty replace the water valve. If the ice mold is full replace the ice maker.
Aug 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
Our kitchenaid side by side refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker stopped working
Check your water line tube, it is most likely frozen. Wrap a hot towel around it for ten minutes or use a blow dryer to melt the clogged ice in that tube. If it still does not work, replace the water inlet valve
Jul 21, 2010 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid Superba freezer side cuts out sometimes
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
I have Kitchenaid Model KSRG25 and need water filter replacement. Need number of water filter to order
If it is the model KSRG25FK, the following filters will work:
4396510 (best filtration)
4396508 (standard filtration)
May 20, 2010 | Refrigerators
I have a GE refrigerator with water and ice through the door. the water through the door has stopped working. the ice cube section is functioning.
A common fault on some GE models is that the water line freezes where it passes through the freezer. The fix is to leave the lamp for the water dispenser on overnight, or defrost the unit manually.
Sometimes you can fix this with a hairdryer, but this can cause fire/melted plastic/electrocution issues.
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
heatman101
ghdh
Jan 08, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer is only cool, everything melting
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
True T-49 Side by Side Refrigerator Commercial Logo
506 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
