Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Do I need a new bulb?
The color has gone bad on my TV. It is mostly red and black at this point with not much other color. Is this the kind of thing a new bulb will fix or is it a bigger (ie. more expensive) issue?
  • richsmith54 Jul 07, 2008
    I will probably opt not to fix this and just get a new flatscreen instead. Thanks for your help.
  • 203 Answers
It sounds like a more major issue than just a lamp because a lamp is either lit, or not lit. On that set it sounds like either main p.c.b. or lcd drive p.c.b. Both of which cost 200.00-400.00 plus shipping and labor to install. Good luck on this, Russmann.
Posted on Jul 07, 2008
  • Rusty Larmann
    Rusty Larmann Jul 08, 2008
    It never hurts to have someone physically look at the set to see if it is indeed something minor like loose solder connections on a board. We know your tv wasn't cheap to begin with. I just hate to see a good unit hit the dumpster. Thank you,Russmann.
Phililips 50 dlp does nothing but the sound. then the red light comes on. changed the bulb but it does the same thing. what is the next step.
Hello, it sounds like one of the cooling fans has stopped in it, sometimes the get clogged up with dust so bad they can't turn causing the set to go into shutdown or a fan has gone bad. try cleaning the fans, bur DO NOT USE CANNED OR COMPRESSED AIR!, use a vacuum and a small paint brush to clean them out. The other thing is listen for a squealing sound, if the color wheel is going bad the usually squeal a bit, but if the picture is normal looking for the time it's on, that shouldn't be the problem.....tks
Sep 14, 2014 | Philips 50PL9126D/37B 50" DLP TV
Green picture think the bulb or lamp had gone
No not the bulb check the color wheel may be damage. Good day and best regards.
Sep 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
Red light flashing screen is green turn off itself
your color wheel/ color main bored has gone bad (red flashing indictating one of 3 things depending on flashing. no power to main board. or to much power/bad board on one of the color boards) or you just need to replace the bulb in it. i doubt its a bulb issue bc you do see a greenness to it at first. but *** will auto shut down till the board is fixed. sorry for the bad news but this is your solution. . if you can tell me what model the tv is i cna find out exactly what it is and how many flashes.
Mar 19, 2011 | Sony Televison & Video
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Spots on picture screen,color not correct
the picture tube has three color production units (bulbs) red, yellow and blue.....since these three colors can be combined to produce almost any color. as you have specified the red bulb might have damaged due to one of the following reasons.
1.continuous usage
2. keeping your tv in standby mode for a prolonged time.
the only thing you can do is call a technician and get your damaged part replaced.
remember please do not try to disassemble the unit yourself.
May 28, 2009 | Panasonic PT-52DL10 52" Rear Projection...
Insignia 42" 1080p flat panel tv
you have lost your chroma (color) circuit the sepia you are seeing is just the black & white picture black and, white is adjustable from red to blue to green tint so; your sepia is an overloaded red circuit i could fix this but, i'm here and, you're there so take it to a serviceman it should not cost much more than $100
Apr 30, 2009 | Insignia 42" LCD Flat-Panel HDTV
Why is the color red is gone
this is because of the color control circuit for the red , its most likely an IC that controls red has failed or even a bad resistor , capacitor , ect .. in that circuit will need replacing
Mar 06, 2009 | JVC AV-27530 27" TV
Tv Problem
check the circuit board for possible loose connection,try to resolder the horizontal circuit and the crt board.
Jul 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Color problems
green overpowering makes me think you have a crt problem. or even a bad blue or red crt.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
