Question about Refrigerators
Locating filter side by side ge refrigerator model gss22jerf cc serieal # hh207749
  • 796 Answers
Here is a link to the MWF
http://www.filtersfast.com/GE-MWF-refrigerator-water-filter.asp
MXRC: (looks like the FXRC)
http://www.filtersfast.com/GE-MXRC-Water-Filter-FXRC-FXRT-9905.asp
Posted on Jul 05, 2008
    Master:
  • 726 Answers
Should be located at the bavk of the fridge, down the bottom
    Genius:
  • 1,847 Answers
GE model GSS22JERF BB keep hearing loud howling noise coming from the freezer size. Don't know the cause
Uh-huh... Ivy Joseph,
Well ...
unless your cat is missing that characterization is going to need some EXPANSION... clarification... definition.
The door is open/closed has no impact on "howling"...??
The unit is OTHERWISE WORKING... (????)
or some issues have accumulated to attract your attention.
Your diagram shows a pretty standard side x side configuration...
a "WORKING" refrigerator won't be howling. An iced up refrigerator can encase the EVAPORATOR FAN... and the howling will be that fan shaft spinning in a FROZEN FAN.
The noise should stop on OPENING the door...
Iced up... can come from several sources
- huge air intrusion
- Defrost circuit failure
Go to the location below to get an idea of how our machine fits together...
The part depicted is the second LEAST LIKELY
failure point (defrost thermostat)... First least likely
is the defrost heater element...
Most likely... DEFROST TIMER (or PCB)
Hope this helps... comment me back with progress questions (I'm usually here daily)
appliance parts
Search Over 2 1 Million Appliance Parts
defrost-limiter-thermostat (and video)
http://www.appliancepartspros.com/ge-defrost-limiter-thermostat-wr50x10068-ap3884317.html
Partsselect
PartSelect Appliance Parts and Repair Help
Jan 05, 2017 | GE Refrigerators
How old is the ge refrigerator model no gss22jerf ww
Sometimes the id plate located on the refrigerator has the manufacture date. Otherwise using the serial number attached to the machine, contact the manufacturer for this info.
Dec 10, 2015 | GE Refrigerators
I have GE refregrator (side by side) GSS22JERF, water is continuesly flowing through the water dispenser . finally I have to shut down water intlet to refregirator. what will be the issue?
You are describing a problem to be either your water valve is stuck open or you may have air in the line creating a siphon. If with the water on, if you unplug the water valve in the back, does the water stop flowing? If yes, problem is door switch, if not, its the water valve not closing. Have you recently replaced the water filter? Did you flush out the air? If not this is called a siphon effect and can cause the water dispenser to run after dispensing water.
Those are things I would look for.
Sep 14, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I am looking for the water filter placement location for a GE profile refrigerator that is about 10 years old. Model # is TPX24BRBB, serial # DV271857. I'm not even sure there is a filter???????
That was strange, I first checked at GE and the model did not exist. I went to our vendor and they had the drawings. There is not a filter in your unit. I would suggest an inline water filter such as the one at the site below. Thanks for asking.
Filter link
May 22, 2010 | GE Profile PSS26NGS Side by Side...
I have a GE GSS22JERF BB that started with failure to dispense ice and water with the lights dimming at every attempt. Now the Relay on the mother board is in a continuous trip mode and the compressor is...
You have a bad main control board ( motherboard ) . Replace this board , and it will fix your problem . You do not have a bad overload . The failure to dispense ice and water , with the lights dimming , is the give away of a bad board .
Jan 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser
My filter is located on the inside of the refrigerator in the top right corner. It twists off and is easy to replace.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
GE SIde by side refrigerator GSS22JERF WW is making a clicking sound and is not keeping cold. We have tried cleaning the back of the refrigerator to see if this would help. But it continues to make the...
Hi!!! your current relay has shorted change it and you should be okay..your hearing your relay cliking its no good..it looks like this and is located by the compressor where the rires go into the compressor..good luck..look at image of the current relay..d1dad63.jpg or location here
Jan 04, 2009 | Refrigerators
GE Side by Side GSS22JERFWW not keeping cold
often there is a cover in the rear of the freezer with some screws remove these and put low temp grease on the fan. The Problem Is %100 The Fan So If You Look Up Your Fridge On Google It Will Tell You Where The Fan Is.
Jan 04, 2009 | GE GSS22JER Side by Side Refrigerator
Refrigerators Logo
263 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
