Question about Kodak EasyShare C743 Digital Camera
Camera Frozen in "On" Position
My camera froze in the "on" position while trying to take a video. I've tried inserting brand new batteries and connecting it to a computer, but nothing will make it turn back on. Any ideas on how to get it to finally turn back on work again?
Hi, I read somewhere that this happens with alkaline batteries, but I have had the same problem with my rechargables (...don't use alkaline batteries in this camera). Anyway, removing the batteries with the camera in the off position and replacing them with fully charged ones usually clears the freeze. I also carry a spare CRV-3 just in case the rechargables go flat and this can help overcome the problem. Just don't leave it in the camera as they are too expensive to have it flatten them overnight!
Posted on Sep 02, 2008
Fix memory error message on camera
Hi there! Make sure the SD card is not locked. There is a tiny slider on the side. If is in the "down" position, the card cannot have new files saved to it. Move the slide to the "up" position, then reinsert the card.
If the slider is very loose, it's possible that inserting it into the camera slides it down, essentially making it useless. I have one like that. You could try a touch of superglue to make the slider harder to move, but I have never tried this and you would need to be very careful not to use too much, and to make sure it's entirely dry before putting it in your camera. Perhaps try a different memory card?
Nov 04, 2014 | DXG 518 5 Megapixel Compact Camera -...
Kodak Camera DX 6490 is frozen in the open position and will not respond...open
Does not look good at all. Try this:
remove the battery. Charge the battery, or place another charged battery. Close the battery cover and switch the camera on.
I hope it now will retract the lens.
Most of the time you only can manage to freeze a camera with the lens in that position, when you remove the battery. That is unwise, because the camera does not know in what position the lens is, when you place the battery and switch on.
If the camera was switched out correctly and it could not retract the lens, it could be there is a mechanical problem in the lens barrel, or the motor (steering) is defect.
Sometimes camera's just die too.
I wide you luck while reviving your camera.
Jan 19, 2014 | Kodak EasyShare DX6490 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
My olympus camera (FE- 330) froze when i tried to deleted photo and the the camera froze and the screen is now black and the lens are sticking out
Try inserting a fully charged battery.
If that doesn't work; you may need a new battery.
Write back if none of these work.
Dec 29, 2010 | Olympus FE-330 Digital Camera
Got a brand new M320. Charged up the battery and
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 02, 2010 | Kodak EasyShare M320 Digital Camera
Canon A570IS lens frozen half way-no power
I have a a570 IS that the lense locked out on. fixing it was going to be the same price as buying new, so I took mine apart and after two tries, i fixed it. I would be willing to take a look at it for a heck of a lot cheaper than Canon can if your willing.
May 22, 2009 | Canon PowerShot A570 IS Digital Camera
Frozen Camera
Common problem.
Part called "Aperture Base" went bad and needs to be replaced.
Apr 02, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
51 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
