Question about Motorola Mobility MoroKRZR K1m Cellular Phone
Motorola Krzr For a while I would just see a white screen and after shutting it then opening it it would work. Then I would open it and no screen would show so id close it and tada it worked. Well now (coincidently after i took a pic last night) The screen will no longer come on at all..... i cant see anything. I can still recieve calls, and the small outer screen still works (but its not lit up). i keep reading to try and do the master reset but i cant see the menu to do it....... I really dont have the money to buy a new phone any ideas?
  • 1 more comment
  • hawnt3d Jul 05, 2008
    same issue with my phone, sometimes I will open it and the screen displays upside down, I can't really afford a new phone right now either.
    The problem with my phone seems to be because it is dirty, I think I have to open it up and blow off the contacts with canned air, or wipe them with some isopropyl alcohol..
    I don't really have the proper tools to open up this phone, or maybe, I just haven't tried yet since I can't easily see the way it opens..
    it only interferes with the main display really, the speaker and everything else besides the camera work fine, when I can get the screen on, and displaying correctly.
    It seems to change the behaviour if I blow into the joint where my flip meets the body of the phone.
  • Anonymous Jul 09, 2008
    Same problem with my krazr. Main screen was spotty and now will no longer work. Outer LCD has no back light. This is most likely a hardware problem like a damaged/loose cable. Sadly, my upgrade is not for 3 more months so I won't be able to get a replacement phone any time soon.
  • gspec5 Oct 29, 2008
    i received 2 text messages last night. they had a weird icon next to the message. when i opened it, it said: 'download incomplete'. i switched on the fone the next day and the screen just went blank. PLEASE help me. is this a virus or sumthing?
Does opening it void the warrenty?
Posted on Aug 13, 2008
Your flex-cable is probably out of it's port. You'll need to open the bottom half of the phone by removing the 4 screws (take off the back cover). Once open. On the top part of the phone, there is a rectangular silver area that needs to snap into its connector. You'll see what I mean when you open it up. Then all you have to do is reset it in the right position and close the phone back up. I had to do this yesterday to fix my phone as I dropped it and the screen went all white.
Posted on Jul 13, 2008
All white or all black screen on K1M KRZR
the phone needs to be flashed by a professional!
Mar 01, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Krzr k1 the screen went white and it shut down.( continuesly )
There is a problem with motorola phones .Data cable between screen and main board use to brake by the flip top screens hindge.Hopefully it is not your problem,if it is then only in service they can fix it by replacing this cable.If it is a software problem then you can try to solve it by yourself.It may work if the software is faulty on the phone.Just follow the link below.
http://motohell.com/
Jul 23, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Blank or White screen on new Motorola Krzr k1 cell phone
i am having a same problem with my krzr phone. it is picking up the screen. solve if you can
May 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Take the phone to a mobile service center and have the flexcable replaced on the phone.
Dec 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
I have a Krzr K1 and it has gotten where when i open the phone the light doesn't come on the screen and it will go on like this for a couple of day then when the screen lights up then the screen on the out...
the same thing happened to my krzr a month ago and i got a new one today at first i would open and close it a few times and it would turn back on but then one day it shut off completely... but it only started happening when i took it to verizon and the lady did something to it.... so yea... i wouldnt get motorola fones anymore... i didnt do it but maybe u guys could try and call motorola and they mite send u a new one or fix it
Jun 19, 2008 | Cell Phones
found the solution to the white screen! it's the flip sensor.. what you have to do is open the phone hard and fast... make it so when you flip it open, the sensor knows when to turn the screen on and off.. this may take up to 5 or more times.. jus keep opening it hard and it will eventually work!!!
Dec 05, 2007 | Nokia 6233 Cellular Phone
Krzr problem with display
hey, i have the same EXACT problem. it was a great phone until that happened.  I took it to a technician and he had to send it in and said it was something with the connection where the screen flips open.  He had to send it in and they gave me a new one because i still had a warranty.
Oct 10, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
KRZR K1 White screen
problem with flex cable(ribon).take it back to the shop
Sep 12, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility MoroKRZR K1m Cellular Phone Logo
219 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
