Question about Whirlpool Refrigerators
My refrigerator is leaking;inside. Water puddling under the vegetable bin. There is no drip tray underneath (?) and i cannot find a drain either. Its an older model; freezer on top...it says inside the freezer "equipped for automatic ice maker";but i do not have one or use one. I rent; the fridge was here when i moved in 3 yrs ago and have had no problems. It has been very humid lately. I also recently had a power outage over 24 hrs. Maybe when everything melted and then re-froze something got clogged? Should I shut everything off and let it all defrost again?
  • largiros Jul 05, 2008
    no drain hole
    President:
  • 1,462 Answers
On the back wall towards the bottom, you should see a gulley with a drain hole in the middle. it is this that is blocked. unblock with something flexible shoved down it
Posted on Jul 05, 2008
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Leaking inside of fridge - puddling below vegetable bins - is that the defrost cycle drain clogged up
In the rear of the fridge is a access panel. Remove it and check that the tray on top of compressor has water in it. If no, which I'm guessing it doesn't, then the drain tube is plugged. I like to cut the bottoms off for better drainage or at least make the hole on bottom a little bigger
Apr 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have water puddling up under my Vegetable bins
Our fridge had the same problem with water under the crispers. My husband removed the slide out bottom out of the freezer section and exposed the galvanized trough that drains the defrost water into the drainage tube that goes to the tray under the refrigerator. Hallelujah! the galvanized trough was rusted through and allowing water to drip into the refrigerator instead of the drain hose. I have not found the trough on any parts lists so he is patching it with putty.
Oct 04, 2009 | Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
May 29, 2009 | GE Refrigerators
Leaking water from freezer
take back panel off inside freezer. you will see a drain tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off ice with a hairdryer and follow up with hot water till it flows away freely.
also check the drain tray heater is ok
Oct 13, 2008 | Refrigerators
Water leaking inside refrigerator
Its the clogged defrost drain. I have the same problem. I just cant find the drain
Jun 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
