Question about Panasonic KX TGA270S Cordless Expansion Handset
Hanset ringer off line
I need to turn on the handset ringer for my panasonci kx-tga270s.
  • Anonymous Aug 05, 2008
    Playing around with handset. Ended up losing earpiece sound and can't hear anything. Can dial out but only for speakphone. Speakerphone connection on handset works. What should I do? HELP!
    Cher2Lou
    President:
  • 1,114 Answers
Hi - You can download the manual from the link below:
kx-tga270s
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 05, 2008
I cannot get my Panasonic base KX-TG5583 to register 8th handsets - only seven
It has to do with the electrical load that each ringer imposes on the line. Each set has a limit on how many handsets you can register with it. If you look on the bottom of the base you will see on the identification plate a data item called Ringer Equivalence Number or REN.
In telecommunication, a ringer equivalence number (REN) is a somewhat arbitrary number which denotes the electrical load a telephone ringer has on the line.
Dec 05, 2013 | Panasonic KX-TG5583 Trio Cordless Phone
The line 2 ringer is off (it displayes message "ringer off line 2" on the number 2 remote phone panasonic kx-tg6700 & I cannot figure out how to turn it back on
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 20, 2011 | Panasonic KX-TG6700 Phone
Ringer
There is a section on setting the number of rings in the manual for the base unit on page 28. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG2740S
c:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.pngc:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.png
Apr 21, 2010 | Panasonic KX TGA270S Cordless Expansion...
I have a Panasonic multi talk phone 2 line phone, model KX-TGA270S. Somehow , it shows "ringer off line2" I can't find a way to remove this. What does it mean? Line 2 still rings
I have a Panasonic Multi-talk KX-TG2740 and I need to change the outgoing message. Anyone know how to do this? (There is no "greeting" button as mentioned below).
Thanks!
Sep 07, 2009 | Panasonic Lands Phones
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
Mar 28, 2009 | Panasonic KX TGA270S Cordless Expansion...
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
How do you get the KX-TGA270S apart to replace the Antenna
Real easy... remove the battery and you'll see 2 screws. then start peeling the phone in half from where the screws were.. the phone may seem like its breaking but it does snap apart... then you will needs a soldering iron to replace the antenna..
Nov 13, 2007 | Panasonic KX TGA270S Cordless Expansion...
Panasonic KX TGA270S Cordless Expansion Handset Logo
299 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
