Question about RCA P52926 52" Rear Projection Television
RCA 56925 Projection TV
When turnin on tv i get like a 3-d image i think the red blue green needs to be align looking in the manual it shows this can be done in the screen part of the menu but on my tv this do not show up.
  • 927 Answers
Good Day, enap;
With no control of the convergence on the TV, you more then likely have a Digital Convergence Power Supply Failure.
Cause: CR19710/CR19713 Diode Failure.
Part Number: New part with added reliability, 227066.
The board is a small one it is about 3" x 6", it's mounted in different places on the TV depending upon the exact/full model number, but it will be located on right side of the TV looking from the back.
Hope this will be helpful, Good Luck, big IRISH.
Posted on Jul 18, 2008
3 colored lines small picture
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
My picture has a red and blue seoaration that looks like an old 3d film
  • Screen looks 3D
69189a5.pngSOLUTION
Feb 25, 2011 | Sony KP-51WS500 51" Rear Projection...
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
My screen showes triple image with green and red siloettes like it should be 3D but it is not this just came on overnight What might be my problem
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | RCA R52WH76 Television
The tv image is showing in three colors....Almost ghost like but in three colors. I checked my connections and tried my blue ray player and the image is still messed up....I did press the magic focus...
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Projection tv has 3 versions of what is on tv instead of one
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 26, 2010 | RCA D52W23 52" HDTV CRT TV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
