Question about Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
My air conditioner works fine except when it reaches the temperature it goes off and then on again. At night this doesnt happen It works fine. Any answers to why this happens?
Richard
  • loveflyng Jul 12, 2008
    Durring the day the A/C unit works fine but at night it will cycle on and off every 30 seconds. Still stays cold, but it drives you nuts. Any ideas?
  • Anonymous Jul 14, 2008
    Yep, my unit reachers the correct temp and then right away starts to turn the compressor on and the termal keeps that from happing a couple of times. Sounds like a bad termisistor.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Frank...your unit sounds like it is running properly fans in A/C generally run all the time and the compressor cuts in and out when the tempreture you have selected is reached,the only exception if these units have a rechargable gas system, i don'tknow wether or not they do, then like dash A/C it will have a low gas protection switch which will cut the compressor off, once the gas accumalates it will turn back on untill the gas is so low that it will not turn back on unless fully gassed,hope this helps......John
Posted on Jan 15, 2009
My problem is the fan never goes off runs 24-7 and you can hear the compressor kick in from time to time. Is something wrong or do they all do that for a roof top unit? Any help on this one?
Frank
Posted on Jul 19, 2008
Why is my Dometic Brisk Air air conditioner not working?
Sounds like the compressor is seized up and the smell is from the clutch slipping when it tries to engage. If that is the case, you need a new compressor at a minimum.
Aug 04, 2014 | Dometic 457915 Duo Therm Brisk Air...
Duo-Therm ac when the temerture is reached the fan will shut off but the compressor stays running
Sounds like you hit it on the head--compressor should turn off when unit reaches the preset temperature.
Jun 10, 2012 | Dometic Rooftop RV Air Conditioner
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
I have a dometic duo-therm. No air coming through ducts.
Sounds like the ducting have come apart in some areas or blocked in some way. Take the supply grills off and with a shop vacuum try and reach as far as you can.
Mar 18, 2009 | Dometic Rooftop RV Air Conditioner
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Duo Therm Thermostat
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
230 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
