Question about LG LD65EL Dehumidifier
Dehumidifier runs but does not condense water.
The compressor and fan runs (high or low) but does not collect water. At times the fan has run without the compressor and occasionally the compressor runs without the fan. Sometimes after being shut off the unit will work properly for an hour or two. The filter is clean, the coils are clean, the basement is 65-70 degrees and the humidity can be as high as 75%. It does not shut off because the humidity is too high. I have let it run for days to check the operation. When working properly, the front of the cover is cold so the freon should be OK. The reversing valve could be actuated and/or a contol board problem?
  • dhmumy Jul 12, 2008
    Thanks. I am trying to find the receipt as there is a repair facility only a half mile from me. Danny
  • awest6444 Aug 10, 2008
    I have the same unit, and again I purchased it about two years ago.
Sounds like a problem to me!! I bought a 40 pint one in 2007 I used it one year, and now it won't condense water! The problem is they make this **** cheap in china the coils leak refrigerant from some point where i don't know. I called lg about the problem they referred me to a repair facility to fix the problem. My only problem is I paid over $170.00 for this thing and they don't won't to fix it. I do a/c and refrigeration so i added in refrigerant and it works now. My thing is if it's a problem with these things the manufacturer needs to recall this ****. That's why i hate that's it is hard to find anything made in the US anymore! My dad have one thats over 22 years old and it still works like new.
Posted on Jun 08, 2009
    Novelist:
  • 121 Answers
It sounds like an issue with the control bord. This dehumidifier should have a 5 year warranty through LG. You will need to have this serviced. If it is under warranty by LG they will either refer you to a local repair shop and they will pay for the repair or they will replace it if you do not have a repair shop in your area. Call them and explain the problem to them. Make sure that you have your reciept. Here is the contact information for LG:
Toll Free Phone Number: 1-800-243-0000
Email: customerservice@lge.com
Keep me posted. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Posted on Jul 08, 2008
Fan running but no water and hot on inside. 50 pint danby premiere dehumidifier
Compressor not running, possibly because refrigerant is low
Jul 30, 2016 | Danby Dehumidifiers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Unit runs but no water collects in bucket. Unit is over a year old and has run continuously that whole time. Up till now it has performed beautifully. Is it just worn out?
Hi;
Your dehumidifier is similar to a refridgerator or air conditioner. It has a compressor and coils, and a fan. Basically, the unit has to **** in air with it's fan, and as the humid air goes across the cold coils, the humidity condenses in to water. If the coils are not getting cold, they won't condense any water, or if the fan isn't running, or the coils are dirty. If you check your unit over, see if you can tell if anything isn't working. Make sure the control knob is set at the highest setting. If the compressor lost it;s refridgerant charge, and won't get cold, it isn't probably worth fixing
Nov 23, 2009 | Whirlpool 75-Pint Dehumidifier
Machine works, but no water collecting
A dehumidifier is basically a cooler. The condenser coil on the outside should feel cold to the touch usually around 34 to 38 degrees, as air passes over the coils they collect the humidity in the air and it then drips down into a collector tray. If the coil does not feel cold it is ether a bad control switch not letting the cooler (compressor) turn on, low on freon, or burned out compressor
Oct 07, 2009 | Haier 45-Pint Dehumidifier
The humidifier runs but is not collecting water... so humidity level never drops.
My brand new frigidaire 50 liter dehumidifier has been on for two days and has not collected water from my damp basement. It is on the factory settings: high fan and "CO" (continuous).
Aug 10, 2009 | Maytag M7DH65B2A Dehumidifier
I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Jun 08, 2009 | Whirlpool Dehumidifiers
Running but not collecting water...
Dehumidifiers have only a few components, and operate on the same principle as a refrigerator, freezer, or air-conditioner.
Components Residential dehumidifiers have a cooling system made up of these primary components:
  • The compressor is the quiet motor (engine) of the cooling system. It's the black, football-size component at the bottom of your dehumidifier. The compressor runs as long as the dehumidifier humidistat (the humidity-sensor) calls for a reduction in the humidity.
  • The condenser is a series of finned tubes, similar to a radiator. It's usually near the circulating fan.
  • The evaporator is located near the back of the dehumidifier, right above the water-collection container. It also resembles a radiator or a coiled-up set of tubes. When the dehumidifier's humidistat senses increased humidity, it cycles on, which starts the compressor and circulating fan.
  • The circulating fan circulates the air over the evaporator and condenser coils.
Principle When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
Jul 29, 2008 | Maytag M7DH65B2A Dehumidifier
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
LG LD65EL Dehumidifier Logo
1,282 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
