Question about Saeco Magic De Luxe Espresso Machine
My dregs drawer is filling up with water - Saeco Magic De Luxe Espresso Machine
  • 515 Answers
Check your brewing unit, make sure the filter on the top is tight.
Posted on Jul 11, 2008
My Saeco Royal displays Dreg Drawer full after about 3-4 cups of coffee. i have cleaned the drawer. where do i find the Dreg drawer sensor to clean it.
hi,
this is normal as there is no switch or sensor. In fact the Royal as well as the Magic and others are counting the number of coffees that you have made between two removals of the dreg drawer. For this counter to reset, you have to remove the dreg drawer while the machine is ON, and remove it for about 10s minimum.
Retry and tell me if it is better.
Hope that helps,
M.
Mar 16, 2016 | Saeco Royal Digital Espresso & Coffee...
Right red light is blinking all the time
Alarm LED:
• Permanently on (one or more causes): No coffee left, water tank is empty, empty the residual water
tray is full (in this case the dreg drawer also has to be emptied to prevent problems).
• Flashing slowly (one or more causes): Brewing unit is missing, dreg drawer has not been inserted,
coffee container cover has not been inserted, service door is open, rotary knob for opening the hot
water / steam is not in the right position.
• Flashing rapidly:Ventilate the water system
Nov 09, 2014 | Saeco Odea-Giro Espresso Machine
I have a message that reads Dregdrawer full but it is empty
the machine is counting how many coffee is made,and then it's showing that dreg drawer is full. If you empty it before the machine showing that's full -machine don't know that you are empty it.Now you have to remove dreg drawer for 10 seconds and then put it back!
Oct 03, 2014 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Saeco Odea: The brew group is jammed possibly due to incorrect insertion? Cannot insert dregs draw and cannot remove the brew group.
I had the same problem. I got around it by inserting just the grounds container (which sits inside the dregs drawer) and powering the machine on. Then the machine reset itself to the home position. It wouldn't do this with the dregs drawer removed, but putting in just the grounds container fooled it into thinking the dregs drawer was inserted. Hope this helps. JRP
Oct 24, 2010 | Saeco Odea Go
Machine won't work due to dreg drawer
Check to see if your machine has an "exit chute" or similar area where from the used pucks are ejected. The area might be clogged with used coffee grinds and causing a false reading from the machine.
Dec 14, 2009 | Saeco Royal Digital Plus Coffee...
Water comes out with the coffee grounds in the dregs drawer
Hi
Inside the door on the right at top center is a lever that goes from - to +. Move the lever towards the + but not all the way.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Apr 06, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
49 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
