Question about GE Refrigerators
Icemaker is not working, trying to locate filter without much success. the freezer is also getting ice on walls. model #gss22jerf cc seriel # hh207749
  • brsheerin Jul 05, 2008
    side by side
  • 2,071 Answers
Here's a good Troubleshooting Guide
Posted on Jul 05, 2008
  • GE Master
  • 19,396 Answers
Check that the evaporator to warm up and drop cubes in the icemaker is working, if water is not getting to the icemaker at all then you may need to replace the solenoid
    Genius:
  • 3,422 Answers
HI,
Please let me know if this is side by side or freezer on top or bottom?so that i can let you know where the filter is.
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
  • Priya darshan Jul 05, 2008
    Please CLICK HERE and scroll your mouse over the diagram.the filter will be beside the thermostat knob..
    Please don't forget to rate or accept the sol. no. 3
    Genius:
  • 1,847 Answers
  • Legin Varghese
    Legin Varghese Jul 05, 2008
    Thanks for using Fixya.
Ice maker is just pouring out water, not making ice cubes. Do I need a new ice maker? It is inside the bottom drawer freezer.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
This is a open question. You did not provide a model number. Your model number is located in your fresh food section on the side wall near the top.
I am going to assume the water in the ice bucket is frozen. If this is the case then you have a leak in you icemaker mold. The mold cost more than a new ice maker, about $80.00.
25472320-3kd4nzpyfrydni0byqzalvn5-2-0.jpg Is this what you have? Go into the internet and you can get a new icemaker for about $40.00.
To replace: back off the two top screws. Remove the bottom screw. With a small flat head screw driver wedge into the back wall conduit connector and disconnect. Lift up and pull off the wall
Feb 23, 2015 | Refrigerators
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
Is there any way that you can take apart the icemaker of a Frigidare model FRT21TNG? Our water got an odor in it and we changed the filter to our water. But we are still getting horrible tasting...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
This is what I strongly suspect. Your water supply or piping in wall is suspect. Take the valve supply line loose from ref. And smell or taste it. orinstallt a strong filter in the line between the
wall and the ref. Its also much cheaper than the filter in your fridge.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 12, 2011 | Refrigerators
I noticed the freezer was not working as well as usual. The back wall of the freezer, by the ice maker (not hooked up) is very hot. What's going on?
The heater on the icemaker is staying on. Be very careful not to touch the bottom of the icemaker and remove it from freezer asap. Do not touch the bottom of the icemaker mold because thios will severly burn you. Take the icemaker out or the freezer wall will start melting.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker quit water line works intermittingly
icemaker quite? hire a new icemaker. industry joke sorry.
First things first, is it cooling ok? if yes then proceed.
im assuming it stopped making ice altogether, and not a matter of making ice but not dispensing.
If your ice bucket is located in the door itself, you have an electric eye icemaker system, which electronically determines if the bucket is full or not. this electric eye system, located on both side walls of freezer, consist of a transmitter board and a receiver board. you could have a problem with these boards, the icemaker itself, a bad water valve, or depending on the model year, a icemaker fill line that can get clogged with ice, but due to a faulty design, a fill tube heater must be installed.
if your bucket is not in the door, but located directly beneath the icemaker, then disregard the electric eye system info and the fill tube heater info as well.
Mar 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigigerator ice maker is not working.
Pour about 2/3 cup of water into icemaker . If it freezes and dumps the cubes , replace the water valve ( the piece the wall waterline connects to on the fridge .). Also check the fill tube inside that fills the icemaker , to see if it is frozen solid . If so , then the water valve seeps and needs replaced . If the water freezes and does not dump , replace the icemaker . Check the coils below refrig , to make sure they are clean of dust , lint , pet hair , etc . An icemaker has to be 5 degrees to operate , and if the coils are not clean , that could bring the temp up to 6 or even higher .
Aug 29, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Side by side refrigerator icemaker not making ice. Hotpoint mdl HSS125IFMD Tried installing new filter. Getting water but no ice being made.
I would first try replacing the solenoid valve which lets the water in. Also, how are the ice cube arms aligned? They should be vertical
Jul 04, 2008 | Refrigerators
Water leaking from freezer compartment and ice maker not working properly
  • the water(in the bottom of the freezer) is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
  • and
  • the icemaker problem
  • it could be that the water valve is slowly leaking water into up to the icemaker and freezing before dripping out of the tube. then when the icemaker turns on the water to the icemaker it is partially blocked by the ice and sprays water all over instead of gently falling into the icemaker.
  • if this is the case then changing the water valve on the back of the machine and defrosting the fill tube behind the icemaker should fix this problem.
May 27, 2008 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
180 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
