Epson Stylus Photo R220 InkJet Printer
Problem for Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
By healthpointe on Jul 05, 2008
The Epson Stylus Photo R200 and R320 Status monitor programs are not available in Vista. Epson does not offer a solution that I know of. Do you have any information on how to monitor the ink levels with these printers?
Thanks for your help. Jack Spence
Same Problem
Jan 30, 2009
-   status monitor will not work with vista-   Guest
Dec 11, 2008
-   since installing my stylus r200 printer on new computer with windows vista the status monitor does not work.epson does not want to know.-   Guest
Oct 20, 2008
-   the same problem -   Guest
Aug 28, 2008
-   Can't get ink monitor to work on Vista with the R200-   jackkaplan
Aug 17, 2008
-   R200 printer will not show the status monitor since I installed vista 32 bit. I do not know what ink needs changing -   lesley556
Best Solution
posted on Aug 25, 2008
Helpful)
whittysandy
Rank: Apprentice
Rating: 94%, 8 votes
When you first turn your printer on, the LCD screen on the epson R320 gives a list of options. If you press the down arrow button, at the end of the options is the list of your inks with their levels. The one that is low or out is flashing. The ink names are abbreviated. This bypasses the Vista problem because you won't have to rely on your computer at all!
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Oct 12, 2009
Helpful)
bod1467
Rank: Apprentice
Rating: 88%, 4 votes
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Epson Stylus Photo R220 InkJet
Questions and Unsolved Problems for Epson Stylus Photo R220 InkJet
Do you recommend Epson Stylus Photo R220 InkJet Printer?
Answer
Answer
keeps coming up jam when trying to print cd. After a few times it does print. I got a new tray but... (More)
Answer
clear plastic strip which runs along back of ink cartridges from one side to the other
Answer
When switched on the far left red light continues to flash. There does not appear to be any blockage... (More)
Answer
Hi i have an Epson Stylus Photo R220 InkJet Printer it dos'e everything but print i have put new... (More)
Answer
Replaced one color cartige and now it says that all are empty and I must replace them all in order... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Aug 09, 2008
it did work on its own ok until i installed another epson printer dx4400 - i uninstalled all epson printers tried reinenstalling r200 status moniter would not work at all -vista said it would try to look for a solution ....still waiting
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
