Router wbr 1310 4 pc fourth cannot connect to the internet
I am connected but no internet page i try ip adress no result three other pc work's fine
    Sergeant:
  • 287 Answers
What OS are you running?
I suspect that the 4th PC is not getting an IP assigned or the security does not match if running wireless.
are you connecting wireless or via ethernet?
As a start do this...
start, run, cmd enter
type ipconfig into the dos window and post back results.
Do this for the non working PC and one of the working PC's
Posted on Jul 06, 2008
I have installed my wbr-1310 to my home computer. My internet explorer works fine on this computer. I tried my laptop which has a netgear adapter and it is connected to the router. I have tried to open...
Check if the Wireless computer is connected correctly to the Wireless Router, and if yes then try to access google.com and check if you have that Web page opened or not, if not thenn check the Wireless IP address of the Laptop and make sure it should be in the same range of the router, or else the Wireless computer will not connect to Internet.
Mar 22, 2010 | D-Link DIR-615 Wireless Router
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like 192.168.0.xxx. If you have an IP address like 169.254.xxx.xxx you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
WBR-1310. No admin logon, only f/w upgrade page
Download firmware from site
http://www.dlink.com/products/?tab=1&pid=WBR-1310&rev=WBR-1310
DLink states the login issue has been fixed with firmware v1.04 3/28/07
Remember to get the right one for your unit model. You must connect a RJ45 cable to the router and computer you have downloaded the firmware to and remember which directory it's in. When it asks for the firmware put in the target location (c:\my documents\xxxxx) of the firmware file. Good luck.
Jul 02, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Unable to connect to the internet
Mike, Try setting up a new connection in Internet Options in Control Panel. Please let me know how this works for you.
thanks
Jan 24, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Cannot access the WBR-1310 webpage
if you are wireless, after a reset you need to connect with the router using an RJ45 lan connector lead. Reboot your notebook, while connect to router and then type in the default address for the set up page normally 192.168.0.1
Oct 05, 2007 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
212 people viewed this question
David Payne
David Payne
