My Telefunken Opus 7 radio suddenly started humming real loud. I went to sleep with it playing nicely, and it woke me up in the middle of the night with the humming. It's about fifty years old, but it has been an exceptional radio. I would like to keep it if it's fixable.
  • Anonymous Nov 05, 2008
    I also have a Telefunken Opus 7 with a loud hum when turned on. I agree with replacing the filter caps (which I will do) Also I onder if the full bridge diode is bad, however, the small in line fuse (top right of chasis) has not blown. I'm going to replace the filter caps and then go from there if still not working.
Could be a bad selenium rectifier as well
Posted on Oct 08, 2008
Replace the two 50uf 250 electrolytic filter caps (they are in one can above the chassis) Don't play it in the meantime unless you have good fire insurance.
Posted on Oct 01, 2008
Replace the filter capacitors in the power supply section
Posted on Sep 24, 2008
My sc40r amp started humming really loud after i had turned it on... it played perfect the night before... but when i went to go play it this morning it started humming really loud then stopped and began...
You take it in for electronic repair. Unless you are electronically adept at troubleshooting and repair this is not DIY. Probably one side of the PA transistors has shorted. You can blow the speaker if you keep trying to use it this way.
Sep 24, 2011 | Rogue SC40R 40W 2x8 Stereo Chorus Guitar...
My iphoneran out of battery and wont charge (i think)
try leaving it on charge for a few hours, otherwise that ipod radio could have damaged it
Nov 02, 2009 | Apple iPhone Smartphone
Alarm Malfunctioning - 2004 Sable
Have your battery checked for shorts. Mine was defective on a new Lincoln. Same problem. Even sat in it at 18 degrees one night to appease neighbors whom my alarm woke up.
Check connections at every possible point if the battery tests good.
Get up 30 minutes before alarm usually goes off and see if neighbor has loud car or slams his car door. Motion sensors can set it off too.
Aug 17, 2009 | 1998 Mercury Sable
8 gig Zune won't turn on!
Possible defective/open battery circuit.
May 21, 2017 | Microsoft Zune JS8-00001 Digital Media...
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Player won't turn on
Loud noise = diode is bad, and the dvd player needs to be repaired/replaced
Jun 16, 2007 | Toshiba SD-K740 DVD Player
2,507 people viewed this question
 Grubhead
Grubhead
