Setting the Date and Time
The date/time needs to be set if/when:
Camera is turned on for the first time.
Camera is turned on after leaving ViviCam X60 without the battery for an extended period of time.
When the date and time information is not displayed on the LCD monitor, follow these steps to set the
correct date and time.
1. Slide the mode switch to [replay ], and press the MENU button.
2. Select [Setup2] with the LEFT ARROW button.
3. Select [Date/Time] with the UP ARROW / DOWN ARROW buttons, and press the SET
button.
The Date/Time setting screen will be displayed:[Setup]
[Format], [On/Off].
4. Select [Setup] with UP ARROW / DOWN ARROW buttons,and press the SET button.
Select the item’s field with theLEFT ARROW / RIGHT ARROW buttons and adjust the
value for the date and time with the UP ARROW / DOWN ARROW buttons.
The date and time is displayed as the format you set.
The time is displayed in 24-hour format.
After confirming all settings are correct, press the SET button.
The setting will be stored and the screen will return to the
Setup2 menu.
my camera tells me to turn off and turn on again and it still does not work. how can i reset or fix...
(More)
my camera tells me to turn off and turn on again and it still does not work. how can i reset or fix it
Our C613 is not reading the memory card when it is turned on. It goes straight to built in memory...
(More)
Our C613 is not reading the memory card when it is turned on. It goes straight to built in memory which only holds 12 pictures. What do we need to do??
