Printer How do I unlock the scanner?
    President:
  • 1,314 Answers
There should be a little switch either right under the cover or on the back or maybe even underneat that should have a picture of a lock and an unlock on it. Slide it to unlock.
Posted on Jul 05, 2008
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
Lexmark x6170 How do I unlock the scanner?
This is the user manual for your printer...
http://www.lexmark.com/publications/pdfs/x6100/eng/ug.pdf
Sep 16, 2009 | Lexmark X6170 All-In-One InkJet Printer
MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Jul 13, 2009 | Dell 1815dn All-In-One Laser Printer
Scanner locked on samsung 3160fn- how do I unlock it?
I think you have to call the service. They will change the hole Scanner. Because you can't unlock the scanner by any buttons or mechanical trick!
Mar 23, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Unlock scanner keeps appearing on my lexmark x85 printer
Go to the Lexmark web site here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
- In the SEARCH BY MODEL box, type in X85 and click SEARCH
- In the SEARCH THE KNOWLEDGBASE box, type in UNLOCK SCANNER. It will show some instructions for the X83, but that was the little brother of the X85, so should work.
Steve
Feb 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
Unlock scanner
lift up the scanner assembly to expose the underside of the scanner. slide the locking clip up from the locked position to the unlocked position. ( red )
Sep 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
Where do I find the unlock switch to unlock the scanner.
Hardware is defective. Call lexmark tech support & get a 20% discount to buy a new printer 800 332 4120
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 scanner locked
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Printer does not work
remove the lock from scanner,switch on scanner and restart you computer. bye
Oct 29, 2006 | Dell A960 All-In-One InkJet Printer
145 people viewed this question
jasbo
jasbo
