Question about Kenwood Audio-Video Control Center VRS6100 Theater System
There was a fluctuating voltage and my Kenwood XD-V323 started blinking its display screen and then stopped working, Was not able to switch it on again. I tried changing the Fuse inside, thiking that it might be gone, but that did not help. Please assist me in this.
  • kamran bits
    kamran bits Apr 10, 2019
    change the fuse
  • 1,557 Answers
There is a downed primary circuit on your power supply board it will need to go into the shop to have the fault found and repaired there is no easy fix to this problem
merry christmas
please rate advice
Posted on Dec 25, 2010
SOURCE:
How can I get sound out of my kenwood stereo system?
Ask the previous owner to demonstrate how it works
Sep 21, 2014 | Kenwood XD-A8 CD Shelf System
Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Sep 19, 2007 | Maytag MFI2568AE Side by Side French Door...
Kenwood Hi-fi component RXD-M1MD is not working
I have kenwood rxd m1md . it was on and it got extra voltage. now its not working.
the current condition is now when I turn it on, the display turned on for 2/3 seconds and then it shuts down. few green -------------- dots blinks starts, some times "auto power control on " also displays.
Please tell me what happend to this unit? which IC or part have to change?
Thank You
Jun 13, 2012 | Kenwood Audio Players & Recorders
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
My GE AC starts to beep when I only turn it on for a while
Probably a bad sensor. Remove the sensor and clean it good or replace it. Todays newer stuff relies on a sensor to tell the beard what the conditins are in the house. The board sends a small dc voltage through the sensor and measures the sensor. Changes in temperature cause the voltage to fluctuate and this tells the brain when to shut down the machine. Long story short the sensor thinks the house is cool enough. Less than 5 bucks a sensor is easy to change out. It has a quick connect, check it for corrosion, with any luck all you need to do is clean it up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2009 | GE Heating & Cooling
Kenwood XD-571S displyaing ''test 00''
TRY TAKING THE COVER OFF AND CHECK ALL FUSES ,,,ALSO BLOW ALL THE DUST OUT OF IT
May 13, 2009 | Kenwood Audio Players & Recorders
Kenwood XD 550 stereo start-up problem
this normally happens with a lot of sets! It usually happens during a Power Failure, Power Surge (Fluctuation) and if the wire of the component is taken out from the wall outlet while the system is on...To get rid of this problem all you need to do is to press the Display button on the main unit, it is located just below the main display! Voltage Selection has got nothing to do with this problem...
Jun 29, 2008 | Jwin JK-777 Nostalgic Stereo System with...
My xd-551 displays protection when i switch it on, how do i fix it
When the unit displays protection immediately, that indicates an amplifier failure - which is not a consumer repair.
Weight out the value of the unit vs. replacement cost vs. repair cost. You'll most likely find that replacement is the most economical route.
May 27, 2008 | Kenwood Audio Players & Recorders
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Kenwood VR-605 display fading out
There is a cold solder connection on the display device, on the display driver board, or on or in the power supply that supplys the display voltage to the driver board. The only way you can repair it is if you have some soldering experience and or some electronic troubleshooting skills. If you go in and start poking around, and you poke at the wrong thing, It will smoke on you, as solid state electronics are very unforgiving when it comes to shorting out something, even if its for a blink of an eye!!! If you really like the unit, take it into a repair shop, as it should'nt cost to much to repair. If the units 3 to 6 years old, Maybe its time to think about upgrading to a newer unit??. Good Luck
Jul 30, 2006 | Kenwood VR-605 Receiver
Kenwood Audio-Video Control Center VRS6100 Theater System Logo
85 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
