Sony Ericsson K530i Cellular Phone Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pc cannot detect my k530i phone storage when connected to pc.but just can see the memory card storage.wat should i do now?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
110
Points
Anonymous
Level 3:
  • Sony Ericsson Master 1,511 Answers
  • Posted on Dec 25, 2010
Anonymous
Level 3:
Answers
1511
Questions
Helped
369213
Points
5354
Try checking it via its PC Suite, you can download it here Select Phone mode from the phone menu if prompted, and if you have done it then try detecting it on the Mass storage, again from the phone menu, (Prompted when connected via cable)
Regards, Waqar
1helpful
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
1helpful
How do i go about accessing my images,music on galsxy s2 via pc
When you connect your cell phone with the supplied USB cable and then connect it to your computer's USB port the computer should detect the cell phone as an USB storage device which you can then open to download to your computer.It this does not work then -
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB mass storage device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
6helpful
3answers
HOW TO INCREASE k530i MOBILE MESSAGE CAPACITY
you can not increase the cell default massege storage...but you can have another option..you can select your memory card as msg storage....
How can i put music in a memory chip with the phone my sd can is busted and cant put music in it how can i put music in the memory with the phone
Connect the phone to the PC as it will be detected as a new hardware and the MASS STORAGE DEVICE will be detected. Now copy all required files to the limit and accessibility to the memory and then safely remove the device/phone.
If the card is faulty then the phone memory will not be sufficient to hold the files.
Jul 19, 2011 • Cell Phones
2answers
How to connect laptop with samsung gt-s5620 thru usb to copy the songs from laptop to mobile
just plug in the data cable from your phone to usb port on your laptop, then open setting from your phone and find pc connectivity then set as mass storage, it will detect your memory card of your phone to your pc, drag the music you want to my music folder in your memory card.
How to format memory stick
If you want to format your Memory Stick Duo memory card while it is inserted in the Sony Ericsson phone, you may get an "Memory or Application In Use" error.
The correct way to format the memory card is to first change the USB port mode on the phone to File Transfer mode while it is disconnected from the Windows PC. Then connect the phone to Windows PC. It will be visible as a Disk Drive in Windows Explorer. Right Click and format it.
Virus found in my phone. at the time of search on off many time. please help me.
To detect and delete the virus in ur phone, connect the phone to the pc through usb port.
Now select mass storage in the phone display options.
This will show the memory card and phone memory in ur pc.
Right!! Now with a completely updated ANTIVIRUS software, scan the memory card and phone memory displayed in my computer....This will detect and deletes the virus in ur phone....
HAVE A NICE TIME....
2helpful
2answers
Virus on cell phone memory card
1. you can remove the memory card from your phone connect it to a card reader and format the memory card or scan for virus.
1. If you have a compatible cable to conect to PC then you can connect your phone is memory card mode (mass storage or data transfer mode) and then scan for virus. if the virus are detected from the anitvirus it's good else i would suggest you to format your memory card.
Mar 28, 2009 • Cell Phones
1helpful
Memory card
First let me know whether the memory card is detected by pc using PC suit.. If it does then ur adapter where ur inserting ur card is not working properly . get a new adapter and insert via memory card or 'direct' , it will work
3answers
Motorola v3 rzr
You mean the software? It should be downloadable off www.motorola.com.
A last resort would be to buy a memory card adapter to put the memory card into. You could also try to MMS them to your email address but you wiull not be able to fit many into one MMS.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
