Question about Siemens Computers & Internet
Operating System not found, Insert Recovery CD, Does not detect HDD, Go to browse for Drivers, HDD found but I do not have the drivers.
    President:
  • Siemens Master
  • 1,314 Answers
Your hard drive is bad and it will need to be replaced.
Posted on Jul 05, 2008
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
Recently, I encountered a problem with my Asus EEE PC. I used the Recovery File within the Hard Disk by pressing F9 on the boot process, and I successfully restored my EEE PC to factory default. Now,...
Yes they should be the same. You should be able to reset the laptop to factory defaults using the provided recovery disk just the the system on your HDD. The reason they have both is because the HDD is much faster than an CD. The HDD recovery system also keeps track of required OS updates and will keep those so you don't have to go through hours of system updates in most cases.
May 09, 2011 | ASUS Computers & Internet
How do i restore my acer aspire
  1. Eject the CD-ROM tray
  2. Insert the System CD, marked Disk 1.
  3. Select Start, Shutdown, Restart
  4. The System disk will be detected and boot into the graphical menu
  5. Select your language
  6. Click HDD Full Rebuild
  7. Remove the System CD and insert the Recovery CD (Disk 2-1), then press OK.
  8. Press OK to install the displayed OS.
  9. Press OK to agree to the License Agreement.
  10. Choose the partitioning that you would like to use and press OK.
    It is suggested that you use the existing partitioning.
  11. The system will begin to restore the factory software image.
  12. Remove the Recovery CD when prompted and insert the System CD.
  13. The system will reboot
  14. Remove the System CD when prompted
  15. Press the space bar to complete the recovery process
Aug 26, 2010 | Acer Aspire One PC Notebook
My frontech e cams driver is not being instlled. i have the cd and everything. Its brand new. plx help
First connect the camera to your computer using the Usb cable and then insert the cd onto your Cd-drive and install the software when it's "atoplay". If it's not autoplay itself, open cd directory/folder and click the Setup file and follow the onscreen instructions.
In case this doesn't fix the installation, you need to run another installation method.
Connect the camera to your computer's usb port, you'll see a pop dialog box with "Found new Hardware" wizard, Click "install from a list or specific location (advanced)" by selecting the radio button, "Next", then click "include this location in the search" and the "browse", locate the cd directory and browse the driver in the cd's folder (don't just click the Cd drive, it might not detect automatically). After you find the drivers, click "Ok" and then, "Next", it'll take few minutes to complete the installation, (if you are prompted with a warning, just click "continue anyway"), when it's done, click finish. You might require to restart your system after the installation is finished.
Good luck.
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
Purchased dell inspiron 530 from best buy, Vista was alreday on system as wll as all drivers, a 2 recovery cds came with system one with Visat the other with drivers. About a wek ago microsoft updated my...
You probably have to try to browse to tell windows where the driver is found. Windows is notoriously annoying at this. Try browsing, or telling it you know where the file is, and then comb through the folders and try to find one the looks right. Once you find the right file or folder, the OK button will "ungray" and you can click it to advance. It won't let you tell it an incorrect driver so feel free to try some that sound right, the wrong one won't install.
Jun 03, 2010 | Dell Inspiron 530 Desktop Computer
If the harddisk conected in your system are not dected
"ASSUMING YOU ARE USING A SATA HDD"
check the bios settings.....
if your hard disk detection is enabled or not...
if yes...(yet your system is not detecting your hard drive)
then....go the manufacturer's site and download the respective sata driver of your hdd (particular model number)...
burn it into a cd...
insert the cd into a usb cd rom/writer.....
then try to install windows.... let the system boots from the cd
at the time when it says "press f2 to install driver"
press f2...
then browse to the location i.i. usb cd - rom/writer and install the driver...
now your system will detect your hdd...
if this info is useful
don' t forget to say thanks...
Dec 16, 2009 | Computers & Internet
Operating system not found
open the laptop you find the reservoir from the Hard Disk / hdd pull outward and return again to you as the hard drive is logged
Dec 15, 2008 | Fujitsu Siemens LifeBook S-6000 Notebook
I do not know how to use my product recovery disk on my toshiba satellite
Insert the Toshiba Product Recovery CD and turn on the system while holding down the C key. This will allow the system to boot from the CD. Select either a Complete Recovery (this recreates all the partitions and formats each one, this may reboot the system several times depending on the size of the HDD and the number of partitions) or Standard Recovery (this just formats drive C:). This will then restore the operating system as shipped from the factory. A Toshiba Tools and Utilities CD is supplied for reinstallation of drivers and utilities without reinstalling the complete operating system.
Jul 16, 2008 | Computers & Internet
Delete everything off
See the instructions below from the support website - you need the discs that came with your laptop. If you do not have them, find an OEM copy of your systems operating system and install. Be sure to download and install all driver software from the Fujitsu Website.
http://support.fujitsu-siemens.com/
Restoring operating system
Using the ”Windows Recovery CD" and the ”Drivers & Utilities CD", you can restore the operating
system of your notebook.
All hard disk contents are deleted during operating system restoration. After this, operating system,
drivers and software utilities will be reinstalled. For this reason you should try to save important data
to a backup medium before you restore the hard disk contents.
► Insert the "Windows Recovery CD" into the optical drive.
► Switch the notebook on.
► Follow the instructions on the screen.
i
Detailed PC knowledge is required for manual partitioning.
You must then reinstall all the drivers. Use the "Drivers & Utilities" CD provided.
Jun 12, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
Computers & Internet Logo
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
