JVC 48 inch projection HD TV took a spark from lamp (short or static electricity) and now picture has irregular horizontal distortion. Can circuit board be damaged? Repaired? Replaced? Cost? Model AV48WP30 manufactured Feb 2002 - LynnCat@bellsouth.net 972-333-3454.
  • lynncat Jul 05, 2008
    Chris - sorry if I did not make clear - this is not an overhead projection tv.
    Master:
  • 726 Answers
No the circuit borad is fine it will be the lamp 100% positive needs replacing i have a over head projecter and the lamps should be replaced 700 to 1200 hours and very costly also.
Posted on Jul 05, 2008
  • 19,396 Answers
You may have damaged the convergence board
  • Ginko
    Ginko Jul 05, 2008
    You need to test, and eventually replace the convergence ICs, after this you will need to perform a full convergence setup procedure.
2 Suggested Answers
  • 726 Answers
SOURCE: jvc projection tv
it will still be the lamp ,it took a spark its been damaged it will cause all the lines in the tv it has nothing to do with the circuit board
Have a jvc projection tv picture is to dark how can i correct this
How long is ur tv projection lamp been inside this tv.If the tv projection lamp been inside the tv like 1 1/2 or 2 years and watches tv everyday like 4 or 5 hours daily.The tv projection lamp life are ending.Replacement of the tv projection lamp,will solved this problems.
Dec 28, 2010 | JVC HD-61Z786 61" Rear Projection HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
My jvc 61 inch tv is turning all green on me .was wondering if the lamp is the problem or something else ..?
No. Lamp can not cause one color to disappear or to be prominent. It is a circuit problem. You will need to consult an Authorized service
Jan 27, 2010 | JVC HD-61Z575 61" Rear Projection...
I have a 56 inch JVC HD TV model# HD-56G647. yesterday when I turned the set on there was a black shadow in the lower hand corner. today it's bigger. i called jvc and they told me to make sure the...
Red light lamp indicator is blicking on my 56 inch mode;# 56G647 tv and the Tv screen is black with no vision of tv and no sound. What sould I do
Oct 17, 2008 | JVC Televison & Video
Jvc projection tv
Jul 05, 2008 | Televison & Video
Green bent line on 48 inch jvc
Check for a burnt resistor on the convergence circuit board. This is usually what happens when the green gets distorted as the green is not adjustable only through the service menu so its either a burnt resistor or a leaky capacitor. Resistor is far more likely. Let me know if you need any further information.
Jan 24, 2008 | JVC AV-48WP74 48" Rear Projection...
JCV HD Convergence Problem.
Replace both convergence IC's......Please confirm Model #
off back of TV and I will help you step-by-step....Requires
above-average soldering skill......................T.
Nov 18, 2007 | JVC AV-48WP74 48" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
