Question about RCA CC6262 Camcorder
RCA CC6262 Camcorder Problem:
I GET JUST A WHITE SCREEN WHEN I TURN MY CAMCORDER ON. I HAVE REPLACED MEMORY BATTERY AND ALSO PURCHASED A NEW CAMERA BATTERY WITH THE SAME RESULTS. IT DOESN'T MAKE ANY DIFFERENCE WHAT MODE YOU TRY (VCR, AUTO OR MANUAL) I STILL RECEIVE THE SAME RESULTS. WHITE SCREEN. PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!! Bill
  • 2 more comments
  • WJJ22 Jul 06, 2008
    SAME WHITE SCREEN PROBLEM. THERE IS NO BROKEN CABLE.
    NOTHING CHANGES ON THE WHITE SCREEN
    YOU JUST WENT OVER MY HEAD
    THE PROBLEM WITH MY WHITE SCREEN STILL EXIST. I HAVE READ ALL THE SOLUTIONS GIVEN AND NOTHING HAS WORKED. THE LAST WEB LINK SENT TO ME DID NOT HELP WITH MY PROBLEM. THANKS BILL
    President:
  • 357 Answers
Hi there, here are all the possible reasons for your problem:
Trouble Checks
Troubles sometimes are caused by simple “faults” that you can easily correct without
the help of a service technician by first checking a few basic remedies.
Before you call or take your camcorder to an Authorized RCA Camcorder Service
Center, look below for the type of trouble you are experiencing. Then perform the
simple checks and adjustments listed for that trouble.
If service should be necessary, the warranty information lists what your warranty
covers and explains how to get service.
No power - • Set the POWER switch to CAMERA or VCR to turn on
the camcorder. The power indicator lights.
• If using battery, it might need to be recharged.
• If using AC adapter/charger, make sure it is plugged
into a working outlet.
No picture - • Open lens cover.
Colors do not look natural on recording - • Try adjusting white balance.
Auto White Balance
During auto white balance, the camcorder
adjusts the white balance.
AUTO to turn on the automatic white
balance feature. No indicator appears
in the viewfinder.
Manual White Balance
1. Set the POWER switch to CAMERA
MAN.
2. Press the menu PUSH dial in to
display the menu in the viewfinder.
FOCUS is highlighted.
If you still have problems, you can call: 800-283-6503 (Toll free inside U.S.A.)
The toll-free Camcorder number operates from 8 a.m. to 5 p.m., CST Monday – Friday for U.S. customers only
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Kind regards
Dustin Ellse (Bearweb)
Posted on Jul 06, 2008
  • 1,512 Answers
Hi
Unfortunately, the camera may be beyond repair. The common complaint from camcorders of this vintage and older, is surface mount capacitors failing, not just a few, but many, all through the unit. It affected most makes and models. Meant that any camcorder 5-6 years old, may not be worth repair, as faults exist in many different places. Fix the display problem you have, to find autofocus problems, or poor performance. I suggest returning the battery to the store for a refund. Explain it did not do the job for you... and cut your losses. Sorry it has to be news like this, but is the best bet under the circumstances.
regards
robotek
    Sergeant:
  • 275 Answers
  • Gandhi Khwairakpam
    Gandhi Khwairakpam Jul 06, 2008
    i think that it will help you in some way
    Master:
  • 848 Answers
It looks like electrolyte cap problem . The CCD
part needs several different voltages, some negative ones. If one or
some miss, you get no picture...
  • gopinath pasupathy Jul 11, 2008
    take to service center to solve your problem completely
    Scholar:
  • 135 Answers
If your display has gone to fritzed out, try moving the eyepiece down toward the stored position and see if it comes back. If so, this cable is likely what you need. The part number for the cable is TCE 244342, and with shipping it ran about $30. Well worth it to keep this camera going.
  • RCA Master
  • 19,396 Answers
Check that is not just a broken cable
My camera screen is white totally no colours no menus cant see anything just a plain white screen it dropped about 13 inches any help
Have you tried pullimg yhe memory chip ad batteries and reloading them. And if camera is that new it should still be under warranty take it back to where you purchased it, dont tell them you dropped it and they should help you or replace the camera.
Aug 23, 2012 | FUJIFILM FinePix XP10 XP11 Digital Camera
Firmware for sanyo e1292
I purchased (used) the exact same camcorder from eBay. It arrived. Same deal as you described - turn "ON" and white screen appears. SO, I went out and got a new battery. Charging it now, so I will let you know the result after charging. This is my LAST go around with this. Normally, I would never buy a camera from eBay, but I've bought so much other stuff I have not had an issue with (including new & used electronics.) Will keep you posted.
Feb 10, 2012 | Sanyo Xacti VPC-HD2000 High Definition...
DCR-SR52E Sony camcorder . White blinking LCD screen.
Hello.
Turn off the camcorder.
Take out the battery and memory card/tape (if there's one), then wipe the LCD screen with a dry cloth.
Unplug it (store it away from sun). Then replug-in the wires in the jack/socket.
Jun 02, 2011 | Sony Handycam DCR-SR82 Camcorder
I have a Sony HD2000 camcorder. When using it the other day the screen went white. On and off buttons still work but all I can see is white.
Jan 31, 2011 | Sanyo Xacti VPC-HD2000 High Definition...
I need a manuel for an rca model cc6262
You can download the required manual from:
http://www.retrevo.com/support/RCA-CC6262-Camcorders-manual/id/3242dj181/t/2/
On the page which opens, click on the GET MANUAL button and follow the instructions on the next page to download the manual.
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa.
Mar 07, 2010 | RCA CC6262 Camcorder
How do I connect my Panasonic PV-L353 palmcoreder to my computer
You don't give enough details. More details would help.
I have a Panasonic IQ PV-IQ403 old palmcorder. I know how to connect it to a TV screen. I am not sure how a camcorder would connect to a computer. Maybe this information can be of help to you. I have separate flap door covering my RCA connections on my camera, located near the battery compartment. I just plug one end of the RCA cord into those connectors and the other end into the RCA connectors on my TV. I have to change the power switch on my camera over to the VCR position (take it off of the camera position). The TV has to be on channel 3 (or 4). I push play on my camera, and I can see what I have recorded on my TV screen.
This might work on your computer monitor. I am not an expert, but this information may be helpful.
May 17, 2009 | Panasonic Palmcorder PV-L353 Camcorder
Need instruction manual for rca camcorder m-cc6262/ s-934220028 please help
Hi
This is very simple. Just go to Google.com In the search bar type in" Manual for a RCA Camcorder,and put in it's Model Number. You will most likely get in a PDF file with Adobe Acrobat. It will come up and simply print it out. I have found all sorts of manulas for electronics from years ago.
Jan 16, 2009 | Cameras
My Camera Wont Turn On..
Will the camera lens come out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
Chances are the LCD screen has failed and would have to be replaced. (ive seen this screen problem when it goes to white or when cracked)
you basically would have 3 options,
1: send it out for repairs to Nikon? ( may cost close to what you paid)
2: Buy a used or new LCD on an auction site (if your gadget savvy and you can replace yourself or have someone do it for you) avg price $50-75?
3: sell your camera on an auction site to use funds to purchase another camera.
good luck
Aug 15, 2008 | Nikon Coolpix L11 Digital Camera
RCA 400x Digital Zoom Mini DV Camcorder
I've got the same problem the only option is to purchase a new cord for 102.50 that I've found.
Apr 12, 2007 | RCA CC9360 Mini DV Digital Camcorder
RCA CC6262 Camcorder Logo
174 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
