Hello! Here is the manual to this TV - hopefully, it will help!
LG 32ld310 User Guide Page 54 of 62
SOURCE: olevia lt 30 hv
You both need to IMMEDIATELY download your warranty from the Olevia website. Read it completely. If you are still under warranty, then contact them IMMEDIATELY in writing pursuant to the warranty and demand that they fix the TV for free pursuant to the warranty. Do not accept "No" for an answer. Document every communication and contact you make, including date, time, who you spoke with (first and last name and/or employee number), and the content of the communication.
Do not delay on contacting them, because the warranty is controlled by the date you purchased the TV. If it passes, then you are totally screwed. Olevia will ignore you.
ALTERNATE SOLUTION:
Do not buy any Olevia or Syntax products in the future. Tell everyone you know to not buy their products either.
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
SOURCE: On/Off blue light blinking, TV won't come on.
Ur power ic inverter board is dead.
U need new one.
Testimonial: "Thanks for the advice. Will try it."
SOURCE: GUIDE LISTING QUIT WORKING ON BRAVIA TV
try go sony web
http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL52W4100&LOC=3
Download up deta
Download Tips (Includes how to download multiple files at once)
SOURCE: Vistron 37'' LCD no display, power light on but no response
Hi
This is a common fault on this model and is down to the main board.
Part number: HH-LCD.PCB.YD-106 Unfortunetly a replacement is one thing i have never been able to get hold of, so i just stripped the sets andf sold them for spares.
