Question about Sony KV-36XBR450 36" TV
Sony KV-36XBR450 36 SCREEN TURNS BLACK ON AND OFF AND BLURRY
My tv which is only six years old has now begun to give me problems. I've read some posts but just want to make sure as personal setting may make a difference. The screen turns black on and off on regular intervals and also the screen or colours are always blurry and not sharp as they should be. Any remedies for the $4600 paper weight would be greatly appreciated!!
Thanks
Morris
    Scholar:
  • 146 Answers
Here is a possible repair for your problem. Remember that this is not deffinet.
This does sound like a difficult problem, it might be better to let a repair shop handel it.
Poor contrast and picture disappears in Vivid and Pro screen modes.
Problem was resolved by replacing C210. The capacitor was breaking down under
operation. Important note: capacitors C257 and C248 are in parallel with C210 and similar
failure of any
one of these three capacitors could cause an identical symptom.
C210 P/N 112776011
Posted on Nov 15, 2008
2 Suggested Answers
jerryg50
  • 1635 Answers
SOURCE: Sony KV-36XBR450 HELP
You are not going to like what I am telling you.
The problem you are seeing is that the emission of the CRT has decreased to a point where there is not enough beam current, and the drive circuits are shutting down the beam bias to the electron-gun. The emission is at the borderline stage where it is on the edge and that is why it turns on and off. Most likely, as the cathode in the electron-gun warms up enough to reach a high enough emission, the bias circuits will switch on. Then when the emission drops just slightly because of the beam loading, there is a fault detected, and the bias circuits are switched off.
When you see the picture, the lack of sharpness (soft picture) is because there is too low a beam current for the electron beam to become narrow enough to be sharp at its focal point. There are circuits in the high voltage section to control focus, but they cannot go beyond what the beam cannot deliver.
The solution would be to change the CRT. This would not be feasible, and the CRT is no longer available. It will also be expensive to pay the labor to have the CRT changed. It would require a tech with the skills to perform the factory level purity set-up, convergence, pin-amp, scanning, and color temperature set-ups.
The labour alone could cost a minimum of a few hundred dollars. If I remember correctly, when the CRT was available for your model, it was costing over one thousand dollars. There are some strip magnets and rubber spacers that will also have to be replaced. Sometimes there may be some other small parts required. This will add to some extra cost.
In your case if the set is 6 years old, there is no gaurantee of how long it will take before there are other types of failures. Personaly I would not fix this set!
I would suggest to get yourself an LCD or Plasma HDTV to replace your set. Stay with a known brand name, and take the extended warranty. For myself, I would buy only a brand name that the company also manufactures broadcast and industrial TV equipment. This way, you know you will have original design, and high quality assembly in the set. You will get what you pay for.
In a very basic context, if you are going to watch in a dimly lighted room the Plasma is a good choice. If you are going to watch in a room that is lighted most of the time the LCD would be a better choice. Both systems are good. It depends on your preference and they way you will use the set.
Jerry G.
Posted on Jul 06, 2008
I have a sony trinitron 36in tv, the screen works fine, colours are all great, no flickering or random shapes at all, its just a little blurry around edges, especially small text, its very blurry and...
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Mar 13, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv turns on but the screen in black....worked a few days ago and last night but now it is giving the black screen again
Change Your Hi Voltage Regulator Triac Mosfet Static Problem...
The Voltage Regulator need a proper Choke to iniate a cold start_up All Sony Trinitron got Heat Problem Paste dry too fast betwen the heat_sink and the Regulator....
Sep 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 10 yr old Sony tv that is blurry
check ur cable conections and see if thay are loose
May 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture coming on
Six blink shutdown is a common problem with this televion one of two switch mode ps ic have failed. The repair may cost somwhere around 150.00 to 200.00 to fix from a technician. If you want the specifics, i can provide them.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
May 13, 2009 | Sony Televison & Video
Jerry G.
Jul 05, 2008 | Sony KV-36XBR450 36" TV
Sony KV-30HS420 turns off all by itself
This is less a solution than a work-around, but it does work for me, and it is free or low-cost.
I have had the same problem on the same Sony (model KV-30HS420),picture fading out to green then black, then turning off by itself,after which sometimes the light blinks 6 times, other times it blinks 7times. This started about four years after I bought it, which is not adecent lifetime for a CRT TV. It would happen anytime from 2 or 3 timesan hour to 30 to 40 times an hour. After getting absolutely nowherewith Sony, which was completely unresponsive and unhelpful, and which refusedto stand by their product or provide any useful information, I wasgetting ready to buy a new LCD TV, any brand but Sony (never buyanything from them again), when on a whim I decided to try one last stopgap solution.
I put a fan up against the side of the TV, blowing into the vents. Ithas been 3 days now, and not once has the fading and shutting downoccurred. So it looks like the fading out and shutting down wassomehow related to heat, and the ventilation seems to have solved it. I don't know why it should be a problem now, when it was not the first fewyears. It is also a mystery why Sony has not been able to figure thisout, since it is clear from online postings that many people have thisproblem with this model. Give this a try and see if it solves theproblem for you.
Apr 07, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
KV-34HS510 Problems
between shipping costs and labor and parts....I would recommend just buying a new Television. You can get a descent 32" CRT for right around $300. Shipping costs are going to be at least $60. If you can find a local repair shop that services that model you can call them to get an estimate to find out what's wrong with it. Could be as small as a fuse to a blown CRT. If the CRT is gone....throw it out.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-36XBR450 36" TV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
