Question about Saeco Magic Comfort Plus Espresso Machine
Dregs Drawer filling up with water
My dregs drawer keeps filling up with water. Each time I make a cup of coffee, a small amount of water is dispensed into the dregs drawer. What do I need to do to stop or fix this?
  • angie1973 Dec 13, 2008
    I have a similar problem, water keeps leaking into the dreggs drawer and also the brew unit, how do i fix this?
  • 515 Answers
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Posted on Jul 11, 2008
  • Fred Jul 20, 2013
    How can I see if it comes from it? It's impossible to brew while the drawer is open.
The dregs drawer is not full of pucks, only liquid
Oh my gawd, I have no idea what you are talking about.
Dregs: Beer making?
Pucks and strong shots: Hockey?
Not as good as before: Well, we're all getting a bit older...
Jun 21, 2012 | Saeco Odea Go
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Saeco Odea: The brew group is jammed possibly due to incorrect insertion? Cannot insert dregs draw and cannot remove the brew group.
I had the same problem. I got around it by inserting just the grounds container (which sits inside the dregs drawer) and powering the machine on. Then the machine reset itself to the home position. It wouldn't do this with the dregs drawer removed, but putting in just the grounds container fooled it into thinking the dregs drawer was inserted. Hope this helps. JRP
Oct 24, 2010 | Saeco Odea Go
Hi there...have the light continually flashing red...have cleaned it all out and everything is puched in etc...any ideas what it could be?
Had the same problem, switch off, take out the coffee dispensing unit. close everything else up, drip tray, dregs box and front door etc then re apply power. It'll clunk and whir a bit then stop. Switch off and refit the coffee dispensing unit making sure it fits flush with the rear of the housing (you can check this by looking through the hole where the dregs drawer fits. power up again and it'll clunk and whir again as it resets the dispensing unit. I hope you'll find that it's ok now.
Aug 05, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Water comes out with the coffee grounds in the dregs drawer
Hi
Inside the door on the right at top center is a lever that goes from - to +. Move the lever towards the + but not all the way.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Bought new machine yesterday.says ventilate which i did,then jumps to dregs drawer full,which is empty and clean what can i do now?
Are you still having the ventilate sign come on? If so, let hot water run out for 10-15 sec.
On the dregs drawer full message- carefully put back the dump box -making sure it slides in right. This happened to me the first time until I figured it out how to carefully put it back. If it is not in all the way, it will keep giving you that message.
Jun 16, 2008 | Saeco Magic De Luxe Espresso Machine
Dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Apr 06, 2008 | Saeco Magic De Luxe Espresso Machine
Magic
when you put the machine do you have water or steam coming out of the valve if yes the brew unit might be block check it out clean it or unblock it cheers
Jan 31, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
521 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
