Rta International Patio Heater Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a brand new pre-assembled unit from Lowe's - same problem! Can't get any propane flow through the valve in the normal position. Spent the last 2 hours just getting the pilot light to work - getting really pissed off!
Mike
Level 3:
  • Master 4,383 Answers
  • Posted on Dec 25, 2010
Mike
Master
Level 3:
Answers
4383
Questions
Helped
1260259
Points
17064
Try having all propane turned OFF. some systems auto shut off for leaks. SO....if you have the valve turned on when you open the tank valve, safety systems stop flow.
LG WM3987HW Combo - drum is filling with water during dry cycle.
Sears Parts Direct is one source of the parts diagrams, https://www.searspartsdirect.com/model/1vc37q1bdj-003204/lg-wm3987hw-washer-parts . See the Dispenser assembly parts diagram for the water inlet valve. If you can watch the entire cycle, try turning off the shut-off valves for the washer inlet hoses after the rinse cycle and before the dry cycle starts. Water should not flow into the washer/dryer with the shut-offs closed.
I've seen inlet valve solenoids fail in the open position or in the closed position. I've never seen a control board that sent open messages randomly. (Sometimes, there is damage to the control board or corrosion or damaged wiring that stops the control board from sending the open/closed message to the solenoid.)
I hope this helps.
3answers
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
2answers
Why wont my old grill work with new propane tank
1helpful
I just purchased a pre-assembled E-310 Weber gas grill from Home Depot. Upon Start up I noticed the flame is very high on each burner (three to 5 inches above the deflectors on high). Also, I notice n
Hey Anon..
WOA...compressed propane is not something to mess around with..I would go back to the Home Depot and talk to the store manager,,(take your receipt and all other paper work for proof), ask him who to see about your issue.. tell him you are afraid to use your NEW grill.(Start at the top!).. you spent good $$$$ and you deserve an answer..or a new grill..
I have a H250IDL heater. All electrical installation is correct. I have converted it to propane with the proper conversion kit that I have ordered from Hayward. My problem is, the gas valve will not...
Have you checked the flame sensor is in the correct position and it clean , and the connection is tight , also check pressure switch is working, tubes not spilt .
I have an Atwood model GC6AA-10E and the water is not hot enough on either gas or electric. Is there any temp adjustment on this unit?
Your 2 separate thermostats are pre-set so adjustment isn't possible although you can purchase a hotter thermostat. Normally the complaints I get are that propane is not hot enough, but electric is too hot, so I'm wondering if perhaps you haven't got a valve at by-pass in wrong position, or defective that may be allowing cold to mix with the hot. Make sure any valve in between hot (top line) and cold line (bottom) are all the way in off position. You want flow in to bottom open, and out the top open, and anything else in between, shut off. Have you actually tested a cup of hot water from tap to see what temperature it is? I just don't see both thermostats as being faulty at same time, but?
This is a new unit - used 4 times. The gas will no longer flow and light the unit. Sometimes I can get the pilot to light but when I turn the valve to light the heater the pilot goes out and nothing. The...
Sounds like the thermocouple is not working or you are not keeping the start or pilot button depressed long enough before turning gas valve to on position. Check to see if thermocouple end hasn't come loose, the pilot should be hitting it. This produces the small electrical current necessary to open gas valve. Hope this helps.
1helpful
Does not heat up
Yes, the electic ignitor may be blown.
Look into the small door in front of the dryer when it tries to start. The ignitor will glow bright orange as it heats up to ignite the propane.
If it doesn't glow, then replace the ignitor.
If it does glow, then check the thermocouple position. It may have moved from its mount. The end of the thermocouple (looks like a bare copper wire) must be almost toughing the ignitor in order to sense that the heat is high enough top allow the propane to start flowing. Re-position it.
If it still doesn't start, then the propane automatic valve is broken; the valve cannot be safely fixed and must be replaced.
I hope it's just the thermocouple out of position...
Sep 28, 2009 • Dryers
1helpful
The valve on my propane tank won't turn off or on. grill lights
suggest you take the tank and trade it in for a new one with one of the propane companies like blue rhino. it's about $15 to $20 and you get a brand new full tank.
Jul 16, 2009 • Grilling
New bbq won't light
try turning the gas down a little while you use a match?
Aug 07, 2017 • Grilling
Top Rta International Heating & Cooling Experts
Paul Carew
john h
Are you a Rta International Heating and Cooling Expert? Answer questions, earn points and help others
