Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
I have two 18 volt cordless drills . both chargers have quit working , and they are not even two years old . how can i get help?
1-800-4DEWALT to find your nearest service center. They can also help you locate the date code to determine your warranty status. On the charger you should be covered for 3 years though.
Posted on Apr 07, 2009
Have the chargers been bouncing around in car or van with batterys in? if so u take it apart and you'll see the solder is broken on the circuit board just carefully solder it again and that should solve it.
Posted on Mar 16, 2009
    Champion:
  • 313 Answers
The charger rearly fail. it must be the battery problem.have your battery tested also the switch of the drill.if the drill runs slower than use to be changed the switch.
Posted on Jul 06, 2008
I need to know what the output needs to be on the charger of an 18 volt jobmate cordless drill.
During the initial state of the charge, the charger operates in a fixed-current mode. This means that the current will be held at a constant rate until the battery is charged to a bit over 18 Volts. During this phase, the output of the charger will not be 18 Volts. This is done for safety and battery preservation; forcing 18 Volts on a battery discharged down to 15 Volts or less could cause the battery to overheat. If no battery is connected, the charge controller may hold the output low until a battery insertion is detected.
The exact behavior of the charger depends on the chemistry for which it is designed, whether Nickel-Cadmium, Nickel-Metal Hydride, or Lithium ion. If the output of a known-good battery is 18 Volts after charging, and it has normal capacity, the charger is working properly.
However, a bad cell in the battery changes things. If you run a Ni-Cd battery down too far, the weakest cell in the battery may begin to reverse charge from the current coming from the other cells. This usually causes an internal short circuit, and the cell will be stuck at 0 Volts. A battery pack with one shorted cell will read 16.7 -16.9 Volts when fully charged, and the drill will not have the peak power it should. The charger will give you a battery fault indication if it is equipped to do so.
Jul 08, 2017 | Drills
New battery when put on charger blinks red and green light
that indicates the battery has failed ,sadly and unless than 1 year old it is junk. Batteriesplus will not repair them.
Jan 22, 2015 | Makita BFR750 18-Volt LXT Lithium-Ion...
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
18 volt cordless 1/2 inch drill batt. woln't hold a charge is it the batterys or the charger 2 years old
If the battery is 2 yrs. old ,and has been used a lot it probably is the battery.
Aug 31, 2011 | Black & Decker Garden
I droped my 18 volt cordless B&D on the floor and
if it went to pieces when you dropped it, I'll just bet a manual won't help you, I'm thinking a case of super glue.
Jun 16, 2011 | Black & Decker 18 Volt Cordless Drill...
Can we use the new 18 volt litheum batttery on the old 18 volt drill
Are you asking if it will fit, or if it will work, or it it is safe?
I can't tell you if it will fit, or even if it will work, but I can tell you this--- If it fits, then go ahead and try. It won't hurt anything, but they may have put the contacts in different places, so it might not work. But do not try to charge a lithium battery on an old charger.
Jun 25, 2010 | Dewalt 18 Volt Compact Drill Kit
Can you use the 9 volt charger with the drill that says it takes 7.2 volts. This is the charger that came with it
THe charger should match the voltage on the battery or you will damage it. A 9 volt charger should not be used on a 7.2 volt drill.
Apr 07, 2010 | Black & Decker CD1800SKA 18 VOLT CORDLESS...
WHERE CAN I GET A REPLACEMENT CHARGER FOR A GREATNECK DRILL?
I have to be the bearer of bad news. These are mass produced to give you the lowest price possible. They are made in Keorea/Taiwan and unfortunately do not make replacement parts. These are sold to any company that pays enough to put their name on it. Shop force makes the same drill and several other brands. So when something goes bad you have to replace the entire drill (only comes in the combo pk). You can't buy seperate pieces. Try shop force or Master craft. They're similar to what you have. Found one on Ebay. IF you keep looking you can probably find a seller with just the charger. Good luck
http://cgi.ebay.com/18V-Cordless-Drill-with-charger-battery-NEW_W0QQitemZ260460074195QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca4a154d3&_trksid=p3286.c0.m14
Jul 31, 2009 | Great Neck 80125/79681 Cordless 18V Drill
Dewalt 18v impact drill
if you use it every day, it would be normal for the battery to be at the end of its life. ni cads are usually good for 300 charges/discharges
Jun 21, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Charger not charging have 2 new chargers neither 1 will work for black& decker 18 volt cordless
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
Mar 08, 2009 | Black & Decker 18 Volt Cordless Drill...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
161 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
