Maytag MEW5530D Electric Single Oven Logo
Posted on Dec 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen that you use when setting the oven temp is reading "20" and none of the buttons work, it is Christmas eve and nowhere is open and I can't find my manual... HELP!
Barrett Palumbo
Level 2:
  • Expert 1,772 Answers
  • Posted on Dec 25, 2010
Barrett Palumbo
Expert
Level 2:
Answers
1772
Questions
0
Helped
501970
Points
289
Sorry to read about your problem, I hope this helps you out.
try to turn off your ckt breakers keep off for 10 secs.. then see if stove resets.. if not you have a non repairable problem at this time....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Help with Calibrating Electric Oven Temps with digital controls?
The thermostat is mechanical using pressure from a waxstat style sender and is not adjustable.
I expect you are measuring with your probe in a different place to the sender unit; hence the differences.
My oven won't go past 350 degrees
If you have multiple elements it is possible that one may be burned out and limiting the high end of operation.. Check all to make sure that none is open and replace as necessary.
Check attached site for parts and prices. If you can get the part number it is possible for you to be able to get it on ebay for less money. No harm in checking. Search Over 2 1 Million Appliance Parts
Aug 31, 2017 • Ovens
1helpful
2answers
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
7helpful
We have a Whirlpool gas range model SF379LEKS that was purchased new in 2004. The oven heats up at first but then stops heating, even though the display says it's still on. There are no error codes. ...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 03, 2011 • Ovens
1helpful
3answers
My GE Profile electric oven keeps shutting off on me, it shows a "F3" code on the screen. What does this mean?
your F3 means: Oven temperature sensor open you cannot reset this type of problem.
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
5helpful
After self cleaning ge oven, door won't unlock
I turned off circuit breaker to the oven and tried to open it. It did not. I did it again and waited for a few minutes, it worked and I was able to open the door.
21helpful
2answers
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 • Ovens
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
