Hi i cant work out how to use my lights for night time driving i can only work out how to have fog lights and side lights how do i have it for normal night driving as there is no option on the car
The fog lights and the headlights work together. the fog light switch is in the on off switch for the headlights push the knob would be pulled out for your fog lights and pushed in for your headlights and just turn to on position
If your horn is not working, check the horn relay before anything else. Press the horn actuator on the steering wheel, and have someone listing within the engine compartment for a distinct 'clicking.' If you hear it, then it's working and the horn component itself may be malfunctioning. The horn looks like a square-mouthed snail shell and should be just behind the front bumper skirt on the driver's side. More or less beside the fog light assembly.
Check on line as well for the replacement...use search engine...2005 Ford Focus Fog Light...also your local salvage yard might have it for less...this should be a plug in unit...so no wiring concerns...Hope this helps.
The fog lights on most vehicles sit directly underneath the headlight bulbs. The ballast and wiring work just like the headlights, so changing them takes not much time. The procedure to change the fog light is as follows:--1) Open the hood and reach down underneath the headlights to unplug the electrical plug from the fog light assembly. Squeeze the top of the release tab and pull the connection off the bulb's ballast.2)Turn the fog light counterclockwise to remove it from the fog light housing.3)Install the new fog light bulb.Then connect electrical plugs properly.4) Test the fog lights by turning it ON.Thanks. you can rate this solution and show your appreciation.
ARE YOU READY
L.H. STOP AND TURN ( YELLOW )
R.H. STOP AND TURN ( GREEN )
TAIL, LICENSE, SIDE MARKERS ( BROWN )
GROUND ( WHITE )
NOW THE COLORS ON THE VEHICAL ARE GOING TO BE DIFFERENT AND YOU WILL NEED A 12 VOLT TEST LIGHT FOR MAKEING SURE YOU HAVE THE WRITE WIRES FROM THE CAR TO THE TOE BAR, DON'T NEED BACK UP TIGHTS FOR THIS
hi from uk the fog lghts? i assume front fog lamps ? the head lights have to be on dipped beam then the fogs will also work but in uk this is so as to prevent fogs only being used (blinding oncoming traffic ) if weather conditions req fogs to be used for poor visibility ? then the side/tail and h/lights must also be on like wise the rear fog light/s operate the same way hope this helps and makes perfect sense ?? all above is assuming bulbs have been checked and fuse/relay and power to each lamp ?
