Question about Soyo DYLT032D 32 in. LCD Television
Lcd 32" Picture flashes and flips like double exposed.....worse when tv first turned on but gets better as it warms but never entirely goes away
I fixed it and will tell you for 15.00 a month..........cash only
Posted on Jul 06, 2008
When the tv turns on there is a flash of a picture then it goes away. i have sound but no picture. is it worth fixing?
From http://www.repairworld.com/ Change all caps under heat sink on power supply board even if they check ok
Dec 27, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv problem
It appears that the power supply is starting to fail on your LCD. Many failures like this one are due to bulge or leaky capacitors that overtime become defective.
Jun 26, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Picture goes off..sound stays on
Make sure the cooling to the TV is not blocked. It is on all the time even when off. Some of the spply cucuits remain on continuously. try uplugging the unit. Let it cool. If it is an older TV the back lighting may be dieing, then it is Tech. time
Mar 25, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Start tv and it has a double picture, after it warms up for a while it goes away...sometimes has 3 lines.. now it is stuck with 3 lines and double pic... what would it be? is it expencive to fix?
More likely to be LCD controller (t-con) board. You should run the TV with the back open and small fan blowing on the suspect board to see if the problem goes away, you can see what the board looks like and buy it here (need to match the P/N printed on the board): http://www.shopjimmy.com/catalogsearch/result/?q=KDL-46V4100
Dec 15, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
The red light on the front periodically will start flasing and the picture goes off. It is progressively getting worse.
I need bit more info about TV problem to diagnose problem.
1- Please check how many times red light flashing as there would be 3 seconds pause between flashes.
2- How old is this TV?
3- Do you replug TV to turn it On or it turns On itself?
Waiting your reply to provide you solution.
Thanks.
Nov 23, 2009 | Sony FD Trinitron WEGA KV-32FS210 32" TV
My Sony BRAVIA KDL-46V3000 Television has messed up colors on left side when first turning it on.....after 5 or 10 mins the picture is normal.. Also without turning on the receiver (only TV) can't select...
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Nov 15, 2009 | Sony BRAVIA KDL-46V3000 Television
Screen goes black
not worth fixing,techs charge at least 65.00 $ an hour not including trip charge.no easy fix. you can get new lcd flat panels for under 500$ now. especially at best buy,ther giving them away
May 19, 2009 | Sony KV-32XBR450 32" TV
PANASONIC 42 PLASMA WHEN YOU TURN IT ON THE TOP ONE THIRD HAS A DOUBLE PICTURE AND GOES AWAY AFTER A SHORT TIME. PANASONIC SAID TO LOWER THE VOLUME CONTROL ON THE TV AND HIT THE CENTER BUTTON ON THE REMOTE...
well did you do that and did it work ? i guess that panasonic doesn't say that for nothing so try that first , and unlike lcd tft tv's plasma need to be warm to get the best picture
Jun 01, 2008 | Computers & Internet
Soyo 32" LCD flat panel
Better to send it back before the warranty expires, the set has issues
Oct 21, 2006 | Soyo DYLT032D 32 in. LCD Television
Soyo DYLT032D 32 in. LCD Television Logo
51 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
