Question about Dell Dimension 5100 (D51L1) PC Desktop
Nothing happens Dell 5100. I push the power button and nothing happens. The green LED on the MB is on. I checked the power supply by jumpering green to black and can faintly hear the case fan runnning. But pushing the power on button causes absolutely nothing to happen. rogercoldiron@msn.com
  • 1 more comment
  • 1022 Jul 05, 2008
    I can't find a fuse inside the power supply. Could it be under the board? I haven't taken it out of the power supply.
  • 1022 Jul 05, 2008
    CMOS battery is good. I've removed and reinstalled everything plugged into the MB. Is there a way to tell if this is a MB problem or a power supply problem before I buy either? Also, any idea where I can get a power supply that will fit?
  • Anonymous Mar 31, 2014
    Nothing happens when I push the power button
I recently had a power outage due to a winter storm. I attempted to power up my 5100 without any luck.
I was told by two co-workers and one of the Fixya folks that it was the power supply unit. I had the same green LED light on the mother board. I brought a new power supply unit and a power supply tester which confirmed that the unit was bad. Replaced with the new one today and I'm up and running again,
Posted on Mar 05, 2009
    Guru:
  • 1,894 Answers
First of all i am having a doubt on the supply from the power switch to the USB connectors to the MB?
another check.
are you sure the processor fan is running.
if ok then remove the MB and place it on a some cloth or non conductor and then boot the board.
check if it boots.
if not get back to me with results.
while replying please mention the name of the expert to whom you are replying.
Posted on Jul 05, 2008
    Genius:
  • 1,142 Answers
*********** board needs a replacement.
Try doing a flea power by unplugging the power cable and diconnect all the peripherals attached to it then push the power button on for 30 seconds that will release the static power from the board itself, reconnect the power cable monitor and keyboard, mouse turn on and see wwhat happens it should turn on thats a very common issue with dell desktop commuters
In case its not on then the motherbord is the suspect.
  • 2,071 Answers
Maybe the push button switch is defected ,the solder of the switch is brittle , or crack or cold,try to resolder the switch, if not change it with new one.I incounter like this problem before in the switch , i only resolder the joint then its ok,,try this also maybe canhelp...
  • Dell Master
  • 19,396 Answers
It is recommended not to open the power supply. If it is the PSU, you should test the power supply using a multimeter on connectors first, and then eventually replace the whole unit.
Generally, when the PSU is gone you do not get any power (no fans, no power to disk drives etc.).
If fans are running it is likely to be something else (eg motherboard) Try removing RAM modules, disk connectors and PCI cards and putting back in place only one RAM module and eventually video card if video is not integrated with MBoard. If computer does not start with this minimal set of devices, and there is power coming to motherboard, then it is likely to be the motherboard.
  • 818 Answers
Your pc is full of
powder? , if yes please clean it.
First check the memory ram installed in the mainboard, do you hear some sound if you take off it?
2 replace the power supply, problably it's the problem, if this not work, the problem is the mb or the vga installed, if also this not work the problem is your cpu.
Sergio
    Genius:
  • 1,665 Answers
    Guru:
  • 1,342 Answers
Have you installed anything new lately? Have you had any storms or power surges in the area?
Things to try:
Replace CMOS battery.
Replace Power Supply.
Try different memory modules.
Remove and re-install all cards on the MB.
  • Georgia B
    Georgia B Jul 05, 2008
    Look for bad or bulging capacitors on the motherboard.
    Click Here for some help on what to look for.
    Master:
  • 726 Answers
U must have a blown fuse in the power supply box(replace fuse) should work fine
  • chris07551 Jul 05, 2008
    full of powder hahahaha what a joke hahaha love u guys
    Genius:
  • 1,847 Answers
Chk the 4 LED on the back of the computer labeled ABCD, and let me know the status?
  • 1 more comment
  • Legin Varghese
    Legin Varghese Jul 05, 2008
    LED status check..
    1-1-3 NVRAM write/read failure. Run the System Set tests in the Dell Diagnostics. If the program does not load, call Dell for technical assistance.
    1-1-4 ROM BIOS checksum failure. Run the System Set tests in the Dell Diagnostics. If the program does not load, call Dell for technical assistance.
    1-2-1 Programmable interval timer failure. Run the System Set tests in the Dell Diagnostics. If the program does not load, call Dell for technical assistance.
    1-2-2 DMA initialization failure. Run the System Set tests in the Dell Diagnostics. If the program does not load, call Dell for technical assistance.
    1-2-3 DMA page register write/read failure. Run the System Set tests in the Dell Diagnostics. If the program does not load, call Dell for technical assistance.
    1-3-1
    through
    2-4-4 An installed memory module is not being properly identified or used. Make sure that a memory module is installed in one of the memory module sockets on the system board. The computer will not function unless at least one memory module is installed.
    3-1-1 Slave DMA register failure. Run the System Set tests in the Dell Diagnostics. If the program does not load, call Dell for technical assistance.
    3-1-2 Master DMA register failure. Run the System Set tests in the Dell Diagnostics. If the program does not load, call Dell for technical assistance.
    3-1-3 Master interrupt mask register failure. Call Dell for technical assistance.
    3-1-4 Slave interrupt mask register failure. Call Dell for technical assistance.
    3-2-4 Keyboard controller test failure. Run the Keyboard Controller test in the Dell Diagnostics.
    3-3-4 Display memory test failure. Run the Video Memory test in the Dell Diagnostics.
    3-4-1 Display initialization failure. Run the Video tests in the Dell Diagnostics.
    3-4-2 Display retrace test failure. Run the Video tests in the Dell Diagnostics.
    4-2-1 No timer tick. Call Dell for technical assistance.
    4-2-2 Shutdown failure. Call Dell for technical assistance.
    4-2-3 Gate A20 failure. Call Dell for technical assistance.
    4-2-4 Unexpected interrupt in protected mode. Call Dell for technical assistance.
    4-3-1 Memory failure above address 0FFFFh. Run the System Memory tests in the Dell Diagnostics.
    4-3-3 Timer chip counter 2 failure. Call Dell for technical assistance.
    4-3-4 Time-of-day clock stopped. Call Dell for technical assistance.
    4-4-1 Serial port failure. Run the Serial/Infrared Ports tests in the Dell Diagnostics.
    5-1-2 No usable memory. Run the System Memory tests in the Dell Diagnostics.
  • Legin Varghese
    If all the led on the back are down (ABCD) replace the power supply.
    Thank for using Fixya.
  • Legin Varghese
    If all the led on the back are amder in color (ABCD) replace the power supply.
Friends computer just quit. Replaced power supply. No pwr up
Did you not wear an antistatic band? If not, you have killed your PC.
May 05, 2010 | Dell XPS 410 PC Desktop
Not powering on at all - I have been built a new computer from scratch with all brand new components. After hooking all of them up and plugging in the power source. Nothing is happening when the power...
1. Could be as simple as not having the Power Switch on the right jumper...double check.
2. The board will power up with nothing hooked to it... just power, CPU, MEM... disconect everything to just to get the board up to the bios.
3. Make sure PS is securly connected to the MB.
4. Check Jumper on the Board to make sure the Test Jumpers are not set
5. Memory is seated correctly... if you pull them out the board will start and beep...
Dec 31, 2009 | Gigabyte GA-G41M-ES2L Motherboard
Computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Feb 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 - no power
It seems that your SMPS power supply may be having some fault...try to replace it...
Dec 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimenion 3000
sounds like you need a new motherboard. Try to reset the bios with the jumper (or remove the battery and unplug it) and see if that does anything, if it doesn't start looking for a new mb.
Jun 04, 2008 | Dell (E210882) Motherboard
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Dell Dimension 5100 (D51L1) PC Desktop Logo
162 people viewed this question
Alun Cox
