Question about HP Audio Players & Recorders
Headset I want to be able to listent to my computer at times but I also need to be able to use a headset for work. How do I use both?
  • 58 Answers
Use both the line out jack hooked up to regular speakers as well as the headphone jack.
Posted on Jul 21, 2008
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
Sound Still Play through Speakers when Headset Connected
Most computers will only pair this earpiece as a headset for voice calls. You need to make sure the headset is paired with your device as both a phone headset and media headset. Check your settings on your computer or smartphone to make sure it is paired properly to play media sound.
Apr 13, 2014 | LG HBS-700 Bluetooth Headset
My recorder isnt working
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution. Thank you for choosing FixYa to solve your problem. The recording feature of your electronic device isn't working properly? You should try turning the volume up on the microphone so it can pick up your voice clearer when talking. If you still can't playback any recordings, check the volume settings of your device on your computer. This is located in the Control Panel (Windows) and the System Preferences (MAC OS) applications of your computer. Go into your operating system's preferences and increase the microphone volume. You may also need to select your headset device as the default recording device (Windows) or the Output Device for recording (MAC OS). If you want my opinion, I think your headset device is not set as the default recording device. If you don't have a headset as the default recording device or output recording device, you can turn the volume up to the maximum setting and you still won't be able to record anything because the computer has another device (if any microphones are installed in the PC) as its default or output recording device. That's why it's important to check your system preferences for a headset to make sure it has the proper settings. I hope you understand this solution and that you can record audio on your headset. Reply back if you need step-by-step instructions.
Jul 01, 2011 | Logitech ClearChat Stereo Headset Headset
I have problem in plantronics dsp 400..regarding mike..i cab hear the incoming calls but i cant hav any conversation in mike..the end user cannot hear..so kindly rectify this problem..as it would be of...
<span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: navy; FONT-SIZE: 10pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">The first thing you need to check is your audio settings and make sure that both sound recording and playback are set to the same device. If you
Aug 19, 2010 | Plantronics DSP-400 Headset
My computer doesn´t recognize the headset. It is possible that this headset can´t be paired with two devices (e.g. a phone and a computer) at the same time?
If your using a bluetooth to connect both im pretty sure there will be a static interfearence and neither may work. Try just using the mic. Please make sure you have installed any software it may need or has come with. Also please look at the Support page at motorola's website and make sure you have properly installed it.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 09, 2010 | Motorola Mobility H375 Bluetooth Headset
Pairing H710 to a computer
Well. This is probably not a solution you guys want to hear, but it just worked. I left it for months, maybe it was just the time, or a recharge needed to wipe out one of the paired devices in memory, but it just paired with my laptop like that. Used it for while too with Skype.
I am also using the new Windows Seven RC this time around, maybe it was a Beta issue, that got fixed with the RC.
Feb 11, 2009 | Motorola Mobility H710 Bluetooth Headset
Trouble ejecting a CD
It's not a fuse because the unit is working.
Try switching and ejecting all cd's. Don't keep trying for more than 2-3 minutes at a time or you could ruin the eject mechanism. Every time a CD comes out, grab it and try to empty the unit. Then look for issues within th eCD's that are causing it not to eject.
Jan 28, 2009 | 2004 GMC Yukon
Big problem with my Nokia N95 !
have you tried updating your phone through the internet? you will need the disc that came with it and an external pc. hook up to the net and follow the instructions to update it.
Dec 31, 2008 | Nokia N95 Cellular Phone
No audio from computer to Motorola S805 Headset
I posted this problem a long time ago. I updated to Windows 7 and my headphones immediately worked flawlessly!!
Dec 29, 2008 | Motorola Mobility S805 Wireless Headset
GPX Mp3 Player
i have n mp3model mw3816 but my computerdon t have the hard drive to record music i need help
Oct 04, 2008 | GPX MW3836 MP3 Player
63 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
