Question about Refrigerators
Frigidaire side by side ice maker, water and ice dispencer inop
I have a frigidaire FRS26ZRG side by side which it's ice maker, ice and water dispencer has stopped working. This dispencer made a slow noise prior to it stopping to work, which then it had a burnt smell.
The light works on the dispencer try if you turn light switch on, but the light will not come on if you select water or ice.
Any ideas and is this something worth fixing due to cost?
Thank you,
  • 1 more comment
  • Anonymous Mar 19, 2014
    Ice dispencer and lights works.
  • Anonymous Mar 29, 2014
    double door, ice and water. Inside fridge cooling, but HOT to touch in front of door wall. Hot water comes out of dispencer at first. Ice not making at all. think it may be evaporator fan motor. Should I replace this first ?
  • Anonymous Mar 31, 2014
    wont dispence water or ice
  • 828 Answers
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Posted on Jul 05, 2008
Changing ice maker for fridadire part # FrS26zrg
Can you add water to the ice maker from tap water, Allow the water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water will point to your as the problem=> 218658000 Water Inlet Valve
If the ice maker sits there with ice and does nothing the problem will be the ice maker=> 5303918277 Ice Maker Assembly
I will be here should you have questions, Thanks Sea Breeze
Dec 08, 2012 | Frigidaire FRS26ZSG
Frigidaire Side-by-Side Model #FSC23LR5JM1, water out of dispenser over time got weaker and weaker... now not at all. Ice maker doesn't fill up either. No visible kinks in line going into or...
sometimes theres filteror screens in the lines or where the water comes out like on the the faucet. could be built up with calcium or something else check the end of the dispencer.
Jul 16, 2011 | Frigidaire Refrigerators
My frigidaire side by side is not cooling. 3 monts old. Ice melted in Ice maker and Water running out icd dispencer on front freezer door.
If you unit is only 3 months old then it is still under warranty so call the store you bought it from and have them fix it.
Jul 04, 2011 | Frigidaire FSC23F7D Side by Side...
I have water running to the fridge and contact at dispencer by I cannot get water to ice maker or dispencer
Look on the backside of the fridge for a small shutoff valve which may be turned off. Also, if your fridge has provisions for a filter, check for a clogged or missing filter. In either case, you will have to replace the filter.
Jun 11, 2010 | Frigidaire PLHS267ZA Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Unit stop producing ice
Boss, please read the following articles in the link. www.hometips.com/repair-fix/freezer-ice-maker.html
don't forget to rate me!!
Dec 27, 2008 | Frigidaire FRS26R4A Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
402 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
