Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
My mower will run if I hold the primer bulb in but if I let go it will stop. I cleaned the carburetor and replaced the primer bulb. My Craftsman mower engine serial number is 143964008.
  • kpschamberge Mar 30, 2009
    My Craftsman mower will only run if I pump the primer bulbbut if I let go it will sputter and stop. I cleaned the carburetor and added carburetor cleaner to the fuel. It still does the same thing.
    Champion:
  • 313 Answers
Check out www.smallengineadvisor.com for trouble shooting & repair. it will help a lot
Posted on Jul 06, 2008
How do you replace primer bulb on model 917.385125 B&S 550 series motor on a Craftsman mower?
the old primer ball is held in place with a round retaining clip remove it just use a sharp screw driver to pry it out then pull out old primer buy new primer and retaining clip put primer in the take a socket that is the same size as ring and that will slip over the primer push the ring in till it seats
Sep 13, 2014 | Craftsman Garden
Lawnmower carburetor problem.
Remove carb float bowl. Check float operation. Float down gas flow, float up no gas flow. Clean float bowl. Observe bowl screw, see if there is a hole or holes thru the screw. Clean out with thin wire, bread wrapper works peeled back about an inch. Use wire to clean out center port of carb. Remove mounting pin of float, remove float and meter needle, clean out port up thru carb with wire. Reassemble try to start. Prime at least 3 times, ensure primer bulb is not cracked, replace if cracked. Replace air filter if dirty. Replace spark plug once a year. Fill oil. 30w. Mowers now have a low oil cutoff.
Jun 14, 2013 | Garden
My mother in-law has a craftsman 1996 22 inch Lawn Mower, model number 917.377532. Just recently my 18 year old nephew had cleaned the carburetor and replaced the spark plug and primer bulb. It worked for...
how long has it been since it was running good? Todays gas goes bad very fast.
It may not be the Nephews mechanicals skills that is the problem.
Dec 03, 2012 | Garden
I have a craftsman eager-1 4.5 hp mowerthat won't stay running. If I hold the primer bulb in, it runs. I've adjusted the screw all the in and it still won't keep running. Any ideas?
Do you hold the primer in or pump it? Pumping the primer forces the fuel into the intake bypassing the diaphragm's intended function. Assuming you pump the primer to keep it running your carburetor is dirty and should be cleaned. Ensure that your fuel is fresh and that your fuel can and fuel tank has no water in it. Ethanol in fuel will evaporate and cause condensation thus creating unwanted water.
Apr 20, 2012 | Craftsman Garden
Mower wont stay run n unless i hold primer in
If it is a float bowl carburetor may have a jet clogged or the primer bulb could have a hole in it. If it is a diaphragm type carburetor, the diaphragm may be stiff and needs replacing. Check it out.
Good day.
Nov 07, 2009 | Toro Garden
My Toro 20016 will start but will only run for a minute. If I hold the primer button down all the way it will continue to run but will die if I release. I have cleaned the float and there are no leaks in...
You will need to clean out the jet on the bottom of the carburetor. The fuel is not being sucked in to engine. Check the needle and seat to make sure fuel is flowing in to the carburetor.
Jul 18, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman eager-1 3.75 mower will not stay running
the engine is not getting enough gas. when you hold down the primer you are bypassing this problem. to fix this simply adjust the carb's fuel screw, located on the side of carb, a little at a time until runs smoothly.
Jun 24, 2009 | Craftsman Garden
Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
May 18, 2009 | Craftsman Garden
Won't stay running
The carbeurator needs to be cleaned and probably rebuilt. Start with a spray carb cleaner by putting 3 or 4 shots in the carb. Run it for a minute then let it sit for two hours and run it again.
May 07, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
99 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
