Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance. Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information. http://www.repairclinic.com/0088_13_1.asp#Level1_1
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your range/oven doesn't seem to work at all, check these:
Main wiring
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors. If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue. Thank you, Dave E. (Illeagle) "Your satisfaction is my personal reward"
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot,...
(More)
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot, with no overhead hood. (also no overhead cupboards) i am looking at the frigidare PLCS389EC. Is this a good choice?
MayTag Gas range (purchased in 1994? approx) burners and broiler function, while main oven doesn't...
(More)
MayTag Gas range (purchased in 1994? approx) burners and broiler function, while main oven doesn't heat nor light it seems.
I accidentally left some racks and Silpat baking sheets in the oven and set it for self-cleaning....
(More)
I accidentally left some racks and Silpat baking sheets in the oven and set it for self-cleaning. The oven is now filled with a thick white powder similar to Christmas tree flocking. How should I clean it out?
