Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
HF289H Hannspree Monitor
Brightness Bar is displayed continuoudly. The exit button on the side of the monitor does not work when I press it. The bar will disappear for a minute and then reappears. How do I remove the bar from the middle of my screen?
  • 3 more comments
  • hhien Sep 08, 2008
    Audio Volume pops up automatically, then turned down to from 100 to 0 by itself, none of the control buttons works.
  • Anonymous Jan 19, 2009
    Same here: The Brightness bar-level just always shows & NEVER STOP! It's starting to get on my last nerve. Maybe it's a virus of some kind made by "evil" competitors.
  • redstepchild Mar 14, 2009
    volume bar pops up continually. will go from 0 to 100 on its own. monitor acts posessed. will automatically go from light to dark and right now the color looks like it went funky too on its own. VERY FRUSTRATED.
  • Anonymous Mar 15, 2009
    same thing
  • Anonymous May 01, 2009
    Brightness goes up on its own. Anyone try contacting Hannspree technical support? I wonder if they'll be helpful about it.
I was having the same problem. installed xtune, updated driver. Nothing
But I finnaly fixed it. Removed the hdmi connector and stuck with VGA. Problem (annoying) solved!
Posted on Nov 14, 2009
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
My hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.
<div style="FONT-SIZE: 14px; PADDING-TOP: 10px" itxtvisited="1"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblProblem" itxtvisited="1">my hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.</span> </div><!-- answer --><!-- from fixya rte -->
May 12, 2010 | HP S7540 17" CRT Monitor
How to control the brightness of Dell TFT monitor
That's the buttonsd on the monitor, not the PC.
Press the [menu] button on th emonitor.
The screen will show the labels of the buttons now.
press the "arrow" to position to the brightness setting (the "sun" icon)
press the minus [-] button to dim
Press [Menu] to save & exit the OSD (on screen Display)
Sep 30, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
Dell 1900f monitor contrast/brightness problem
CLick start/run then type in dxdiag. Go to the display tab and click test dirext3d. There should be an 3d cube that comes up and spins around. After the cube leave cancel everything else and close dxdiag, Your problem should be solved for a pretty long time. If it happens again just follow the steps again.
Jun 11, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
I have a hannspree 19" flat panel monitor
if there is no physical button located on the monitor itself, use your cpu's sound adjuster. it should be located on the task bar on the bottom right hand side. You can also access it in the control panel window under sounds and audio devices.
Jan 27, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
Oct 11, 2008 | Compaq 7500 17" CRT Monitor
While in the On Screen Display Menu the Icon second from the bottom contains settings for OSD timeout, you want to get to this function and set it to 20 seconds.
This is a link to the online PDF manual, go to page 18 for more detail on accessing and using this setting.
On page 19 is the information on resetting the factory reset functions. Do this, if you are struggling with the use of these buttons, read the manual for assistance. The manual is something you can read and reread and may help you immensly in getting to these controls.
On the last page of this online manual is the contact information for Hanspree and they have a toll free numberr. Wait until the weekend is over before calling. If anyone is working the phones on a holiday weekend they are low on the seniority list. You may or may not get good service on weekends.
Jul 05, 2008 | Gateway FPD2275W LCD Monitor
Brightness control
Press the exit or menu button twice.
Jul 05, 2008 | Hannspree Computers & Internet
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
1,222 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
