Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washer
Acks like its unplugged
TIM LOOKED AT THE WIRES AND MADE SURE THINGS WERE TIGHT AND ITS WORKING. WE STILL HAVE A VISIT PLANNED THIS FRIDAY FOR A CHECK UP.
Posted on Jul 10, 2008
Whirlpool duet sport dryer will not power on no lights nothing
check inside, white fuse should be near air flow . also near themo couplers, take volt meter ,place on continutee, first unplug unit. remove one ,of the two wire's. check to make sure circutt is closed ... if not rplace fuse.
Sep 15, 2012 | Whirlpool 279818 4Way Vent Kit for Duet...
Whirlpool Duet Sport won't work past the wash cycle. It's full of water and will not drain.
check the pump filter it could be blocked or the drain hose try blowing down the drain hose to see if its clear you should hear a bubbling sound if not its blocked
Nov 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Had to stop my whirlpool duet sport front load washer to add a garment, pressed pause, now it will not resume, is there a reset. i turned it off, unplugged, etc. has power but will not continue the cycle...
Try unplugging for 30 minutes, then try to start again. If this doesn't work you probably have a contol board or door lock problem. Good Luck, Appliance Specialists
Feb 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cold water keeps filling even when washer is off
if it still flows with the unit unplugged then replace the cold side inlet valve for the fix , it my be called the mixing valve on a part search. Phil
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
81 people viewed this question
Dan Webster
Dan Webster
Sal De
