NEED A REPLACEMENT POWER SUPPLY FOR Grundig TV GULCD32HDIT?
  • 372 Answers
Hi.
Checked with one of my suppliers for this PSU & it came back as obsolete spare.
Can you give me the ident numbers on your PSU so I can see if I can find A supplyer for you.
Posted on Jul 05, 2008
My grundig tv /combi (video) has sound but no picture? is there anything i can do to fix it?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 23, 2017 | Grundig Televison & Video
My tv screen went off now sound is on but screen is like on but you can't see even menu Type grundig led 37"
Nov 28, 2015 | Grundig Televison & Video
Grundig Xephia 42 in.stuck on stand by
Probably the internal power supply has failed.
Nov 22, 2013 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Tv wont turn on
Hi
Normally Grundig tv sets when stop working the standby light is on. If it is so the power supply is faulty. You should check DC supply voltage in pin 6 of SMPS IC TDA4605.. If no voltage in this pin, check the limiting resistor connected in series. If these parts are OK, check the supply line rectifier diode for short.
Sully
Sep 20, 2013 | Grundig GF70-600 TV
Powersupply went off while the current supply was disrupted for grundig Tv
Possible that the main power supply which is a switch mode power supply- SMPS - has failed.
Please check the link below for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jul 08, 2011 | Televison & Video
Hi i have a grundig gu22dvd the power supply keeps turning off can i buy a new poers lead and transformer
helen366, if unit continues to do same thing, I suggest you contact Grundig for warranty service to put it right again!!! You must tell them that it should not have premature failure of the internal "switch-mode-power-supply" and they should replace the unit with new or refurbished same model free of charge.
12fixlouie
Sep 24, 2010 | Grundig GU22DVDPX 22 in. LCD TV
Moving home resulted in our loosing the AC adapter for our Grundig YB 400 PE, any sugestions where we could aquire a replacement?
its a 9V power supply
you should try Radio shack take with you the the radio to make sure the power supply have the correct connector
Aug 23, 2010 | Grundig YB 400PE AM/FM/SW Radio
Grundig Cinemo TV will not start
The power supply could be failing.
Jun 02, 2017 | Grundig Televison & Video
Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Grundig GU22DVDPX 22 in. LCD TV
The remote control sensor within the Tv appears to be faulty where can i purchase a replacement?
With a high-end TV like a Grundig, I wouldn't risk touching it with a screwdriver.
Please contact your local Grundig authorised repairer, its cheaper than replacing the TV.
OR
Replace the batteries on your remote!!!
Oct 12, 2009 | Grundig GU22DVDPX 22 in. LCD TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
