Printer not working for labels - Office Equipment & Supplies
  • 1 more comment
  • Anonymous Aug 05, 2008
    My HP LaserJet 1320 will not print labels
  • Anonymous Sep 15, 2008
    The printer won't pull labels through. The little rubber pad that spins to catch the paper won't catch the label sheet. I used to be able to bend the edges of the labels in order to force it to catch, but that won't work anymore.
  • Anonymous Apr 16, 2009
    Labels will not print. They are Maco ML-8100 labels. The printer takes about half the sheet and stops.
I have a HP Photosmart C7200 All-in-One series. I lost my manuel and do not know how to print Avery 05200 labels. Please help me.
Thank you
Sue
Posted on Sep 03, 2008
Can you give more details on the issue that you are experiencing? What type of printer are you using? What type of labels are you attempting to use?
Thanks.
Dave Carmany
OnlineLabels.com
http://www.onlinelabels.com
Posted on Jul 06, 2008
Can Cymo lables be used in the Smart Label Printer 100
If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
Feb 13, 2014 | Seiko Smart Label Printer 100 Thermal
Printer printer duplicate labels
i have the same issue, this case happened when out of paper or ribbon, while this program and label form works fine with the zebra printer
Oct 18, 2012 | Intermec EasyCoder PM4i Label Printer
How to adjust intermec to print thicker labels
Only user Intermec Labels or they will probably not work.
Feb 20, 2012 | Intermec EasyCoder PC4 Label Printer
Label double print
It's possible that the printer did not get a good calibration on the size of the label. There's an optic sensor looking for the gaps in the labels. A test would be to turn the printer off and back on again. When it is ready, just press the feed key. If one label advances then the printer had a good read on the label size. The idea is to see if the printer works ok by itself first.
Now print a label - if you get two labels then you have to look at the software / printer driver as the cause. The printer will only do what it's told to do.
Hope that helps !
Apr 14, 2010 | Zebra LP 2844 Thermal Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Manual calibration of labels not working, printer not feeding labels correctly
printer manufacturers has different standards depending from the varieties of model and brand of printers for example an epson printer model who is older version is not the same speed print with the recent model likewise with the other brand. Therefore calibration of labels is depending to the version of the printer you are using now.
Apr 22, 2008 | Zebra Z4Mplus Label Printer
Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Mar 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Fault Alarm light is on
I have the same problem , the printer tries to work in some moments then it stops. It can not make any label out , any rolling.
Dec 14, 2007 | Datamax DMX E4203 Printer
526 people viewed this question
k24674
jasbo
jasbo
