Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loader will not drain or spin
We were washing a large pillow, and all was good until the spin cycle. Now we can't get the washer to drain or spin. Flashing error code F02, I think, when we got to it. Tried unplugging and re-plugging, tried drain and spin with no spin, nothing works. We tried starting a different cycle, and it will add a little water and agitate for a few seconds, then it does the same thing over and over. Click, click, low hum. Please help...I don't want to have to spend a huge amount of money to fix or repair!
  • lindemanns Jul 05, 2008
    Oh my gosh! This site is the absolute best!!!! Your VERY quick response helped us REPAIR OUR OWN WASHER!! When we opened the pump housing, we found a small piece of plastic was keeping the impeller from turning...all is well again!! I have this site bookmarked and will return here often for any assistance! THanks again and have great rest of the weekend...I know WE WILL!!
  • 413 Answers
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel (three screws along the bottom). There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
    New Friend:
Excellent advice from Richard. I had same problem with F02 code during rinse cycle. Checked the pump filter and found it was full of gunk. Also had a scrap of material on it-shoulder pad? Bra pad? (The smell was vile). Cleaned filter and put it back in place. I also checked under the gray rubber gasket located just inside the door around the front of the drum and found a camera pouch and a gift card. Amazing! Check these periodically because people leave things in their pockets. Just ran a load and the washer worked perfectly!
Annette
Posted on Dec 07, 2013
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
GE Top Loader - Spin Cycle Problem
bad door switch, probably ripped out by a comforter or pillow
May 29, 2008 | GE WBSR3140DW Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Whirlpool Duet GHW9150P Front Load Washer Logo
155 people viewed this question
Dan Webster
Dan Webster
Sal De
