Sound problem After repair my this computer my sound devise is automatecally removed and i will try many time to instl c media and Realtek audio driver but not istl audio driver please tell me which driver is nedd to instl.
Posted on Jul 05, 2008
I am already install realtek high defnition audio drivers but that is not working At the time of playing any media file using windows media player , it shows an error message that is "Windows...
go to control panel-sound-default audio device & check which device is enabled as default device. In case of HD audio remove the speaker jack & reinsert, if that port is selected as default audio then you should get an immediate message saying 'audio jack plugged in'.
Jun 09, 2011 | Computers & Internet
My acer t310 no sound.. maybe because i didn't install sound card or something
You need to install the audio drivers for your computer. This can be found on the disk that came with your computer. Click here to download the audio driver On-Board Realtek RTL8100C. Or you may need to install the Onboard C-Media Audio driver it is located a third from the top. Depends on the audio controller used on your mainboard. Try the Realtek one first, if this doesn't work then try the C-Media audio driver.
Thanking you
Nov 09, 2010 | Acer Aspire T310 PC Desktop
No sound on my computer , example no sound in media player/yahoo voice chat , no sound at all even the Icon of Speaker dissappear from task bar, get pop up window saying the realtek audio driver need to be...
its because sound card drivers are not installed in your pc .try installing it from the motherboard drivers disc provided to you with the board or else download free drivers onlline by searching for realtek audio drivers.
Mar 06, 2010 | Apple Mac 10.5.1 Desktop
Intel E5200 Dual Core 2.50gHz 500GB Sata HDD 2GB RAM Asus Extreme AX700 graphics card 256MB Windows XP Pro SP3 After a fresh installation of Windows and loading of all the drivers in the Disc supplied,...
Go to devise mgr and look at the sound hardware under sound, rt click on realtek and click on properties, look at driver, does it say windows or realtek,and check version and date,then go to realtek
and see if the driver is the newest and the right one for your hardware.
That was great that you listed some info,but the wrong info,ex for OS, you should have listed the motherboard model #, you should post back the model# and what it said under driver,version,date of driver. Then someone can check to see if the correct driver is installed.
Mar 21, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
WindowsMediaPlayer silent on Toshiba laptop; sound faint on Skype
GOTO CONTROL PANEL-- check the audio devices, see if its set to the default device under playback and recording device, default is realtek,,,
Feb 03, 2009 | Toshiba (P000377700) Computer Speakers
REALTEK REMOVED MY WINDOWS SOUNDS!!
Solution:
best sol: go to start button ----->click RUN----->Type devmgmt.msc in Text Box ----->
              Device Manager windows appears , click on Sound, video and game controllers(+),
              if you see "Realtek AC97 drivers"(if they are visible...) then we can make sure that sound                     drivers are loaded in ur system, otherwise you have load it again.....
                                                          or
i) my best advice would be, dont mess up with installing, reinstalling, uninstalling sound drivers rather try   to format or reload your OS again(Windows XP) and then install drivers.
ii)  try to check volume on your speakers, volume in windows or system , volume in media players sometimes they may set to mute of no volume.......
iii) try to check all sound physcial connection that run from your computer to speakers, including power connections, cable connection ....or just remove and replace them(reseating...)
iv) try connecting a headset to your sound port, sometimes your subwoofers or speakers may fail.....
Thanking You
M. Sridhar
Dec 27, 2008 | Digital Audio OMX-LE (OP428LE) PC Desktop
No Sound
ATI is the graphics card developer. Your motherboard has onboard audio that appears to be Realtek. You should not have an ATI sound driver... as they don't exist.
I'm assuming you're using WinXP to make thing simple. If you're using Vista, try to do the equivalent.
Since your graphics card is capable of HDMI, the problem could be that the card expects to output audio through your graphics card rather than the sound card. Check start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings -- go to the Audio tab and make sure it says Realtek for output. If it shows more than one output device, set it to realtek. If it doesn't show realtek, follow the below instructions, and then double check at the end that the Output device is set to Realtek.
1>Please go to HP's site and download their Audio drivers.
2>Go to Device manager -> Sound, Video, and game controllers.
2.1> Does it have an entry saying "Realtek blah blah Audio" there? If not, what entries does it have for audio? Ignore Audio Codecs and Legacy Audio Drivers.
2.2>If there's nothing there, you need to install the drivers you downloaded. If there is something there, please continue to #3.
2.3>After installing the driver, restart computer.
2.4>Once computer is restarted, go start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings. Hit the button labeled Advanced and adjust the speaker setup to whatever you have - surround sound, 5.1, quad, stereo, whatever.
2.5> Go to #5
3> If there is anything that says Realtek/Azalia Audi, right click it and Uninstall.
3.1> Restart computer.
4>Install audio driver you downloaded, and perform #2.4.
5>Find the driver icon (there's probably on in the task tray) or find it under start -> Control Panel -> Sounds and audio. Set your speaker settings there as well. Audio I/O should specify what ports go to what speakers What you set in windows should match the Realtek audio manager's speaker setup.
If problem persists, please report this.
Dec 14, 2008 | Computers & Internet
Sound problem
if ur usung win xp OS U shold restore OS (pgm-accessories-system tool.restore )to back date while it in workinfg fine
Jul 19, 2008 | Edirol UA-4FX External Sound System
NO AUDIO OUTPUT DEVICE IS INSTALLED
windows key + R = open : devmgmt.msc
Sounds, video and game controlers > (right click) Realtek high definition audio > update driver sofware > browse my computer for driver software > let me pick from a list...> double click on Realtek high definition audio > YES to update driver warning > AND SWEET SOUND IS AUDIBLE :D
Dec 14, 2007 | Microsoft Windows Vista Ultimate Edition
No sound from left rear speaker
speaker connectivity problems
get for repair
or trying installing audio driver again
Dec 03, 2007 | Logitech Z-5500 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
