Question about Estate TAWX700JQ Top Load Washer
WASHER WILL NOT SPIN
MY MAYTAG TOP LOAD WASHER WILL NOT SPIN ON THE SPIN CYCLE, THE AGITATOR KEEPS AGITATING. IS THIS THE CYCLE SWITCH GONE BAD?
  • COMPMAK Jul 06, 2008
    I'm also hearing a grinding noise from the machine as it trys to spin?
  • Anonymous Aug 04, 2008
    I have the same problem with the spin cycle not working and hearing a grinding noise.
    dave
This is probably a timer problem. In maytag washers the motor turns in one direction to wash, the opposite direction to spin. The timer decides which direction to start the motor.
Posted on Jul 06, 2008
Mav7600aww maytag spinning but not agitating
RDU Appliance Repair 919 827 1482 Serving Raleigh Cary Durham NC
mav7600aww has a brake that goes bad. some will just spin slowly during agitate cycle and not really agitate
Sep 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
My washer agitates drains but wont spin until i manipulate the switch to wash make it agitate fo a couple of seconds than switch it to spin cycle than it spins
sounds like your timer is bad this is the selector for spin wash ect... This is not a hard repair the back comes off the back top of the washer to exspose the elect controls you will need to unplug it then pull off the knobs and remove the two screws. Make sure to unplug the unit from electricity first. good luck.
Aug 10, 2010 | Maytag SAV2655A Top Load Washer
My Maytag washer agitates, and will pump during the spin cycle but will not spin
Check the lid switch is operating. It will not spin for safety reasons if it thinks the door is open.
If the switch is good test for power at the wigwag (spin) solenoid when in spin cycle. Since it agitates the solenoid itself could be bad.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Whirlpool top loading washing machine not finishing cycle
SOUNDS LIKE A PUMP HAS GONE BAD. REPLACE IT. IT WOULDN'T COST TOO MUCH.
May 14, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
273 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
